New plugs cause p0300
Old May 20, 2005 | 06:36 AM
robertearl's Avatar
Just put in a set of Bosch platnum spark plugs. I am now getting the code p0300 which is multiple cylinder misfires. Anyone else have problems with these plugs?
Old May 20, 2005 | 06:38 AM
pHEnomIC's Avatar
Re: New plugs cause p0300
You probably didnt gap them right, didn't tighten them enough, didn't connect the wires correctly, or you could have router the wires in a fashion that could cause one of them to burn.
Old May 20, 2005 | 07:12 AM
....or you cracked an insulator, or didn't tighten one of them all the way, or.....
Which Bosch plat's are they.... single ground, double ground, quad ground elctrodes?
Old May 20, 2005 | 07:17 AM
robertearl's Avatar
They are the single ground plugs. I did them while I was changing the k-member. It is REAL easy with the k-member off. Plugs were torqued and installed with anti seaze and silicon lube on wires. The plugs were all gapped to .050.
Old Jun 15, 2005 | 02:43 PM
blind527's Avatar
I just got this trouble code and all my trouble codes came within 45 minutes of driving. My plugs are fine, and gapped right, I believe it's a spark plug wire that needs to be fixed.
Old Jun 15, 2005 | 02:46 PM
OBE1 95Z28's Avatar
When my motor was stock my car ran like crap with the Bosch plugs, immediately after I changed to them. Replaced them the next day with new stock AC Delco plugs; problem solved. All the boots were on properly too.
Old Jun 15, 2005 | 02:52 PM
blind527's Avatar
I have NGK TR55 plugs, will be testing for arcing and burnt wires later.
Old Jun 15, 2005 | 04:39 PM
CamaroSS30thAnn's Avatar
i hear tha platnums are crap for our cars, many ppl have problems with them ,
u could have crossed wires, gapped em wrong, id put my money on the plugs being teh problem
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
Xiantyl
Jul 21, 2015 05:42 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
