new piston rings?
Old Aug 31, 2004 | 07:37 PM
kacy's Avatar
new piston rings?
i bought a car for parts and tore the engine apart and found no cylinder rigde. the car read 155k on the odometer i was told if it wasnt burning oil not to replace the rings anyone ever had the same situation
Old Aug 31, 2004 | 11:37 PM
kacy's Avatar
Re: new piston rings?
ttt
Old Sep 1, 2004 | 05:38 AM
Dave C. '97 Z28's Avatar
Remember the ridge is about 1/4" down the bore, not at the top edge. It's where the rings stop traveling up.
Do a compression check, and if it's good then you're probably okay if you really don't want to change them.
If it was me, since the engine is apart, a machine shop will usually only charge about $40 or less to remove the ridge and hone the cylinders, then a new set of performance rings will cost you about $75 or so.
So for about $115, you won't have to worry about them for another 150K miles.
-Dave C. '97 Z28
Old Sep 1, 2004 | 05:22 PM
kacy's Avatar
it was measure and only has a 1/2 of a thousands tapper from the top to the bottom of the cylinder
magman
Apr 15, 2016 03:08 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
