New personal Best... What do you think
Old Sep 18, 2006 | 04:06 PM
93redbird's Avatar
97 TransAm. A4 WS6
Mods/setup include:
Nitto's
Hooker Catback
Zex Wet Kit. 150Shot.
Ram Air w/ k&n filter
Cats hollowed out.
3.23 gears.
B&M 3000 Converter
Off the spray:
1.8 60Ft
8.8@78MPH 8th Mile
13.8@97MPH
On the spray:
1.6 60FT
7.81@87MPH 8th Mile
12.294@109MPH
ON THE SPRAY:
From what I understand my MPH is low. Could this be due to bottle pressure issues. I ran 3 runs. My first run was 12.3@112mph but I didnt spray out of the whole on that one.
OFF THE SPRAY:
Why the hell am I so slow. I ran 13.7@100 on my stock 93 TA when I owned it and the transmission sucked in that one. Could that 3000 stall be too big for my stock setup?
Old Sep 18, 2006 | 04:44 PM
CamaroRacing12's Avatar
Re: New personal Best... What do you think
yea u should be runnin better then that..... just practice i guess
Old Sep 18, 2006 | 04:51 PM
redneck01's Avatar
check and see if you have any knock reading..sometimes they get a slight knock from the nitrous if not really tuned for it. rare, but possible. your stall is fine, just pay attention to your 60' times and make sure the stall is consistent and truly flashes to 3000rpm. you should be in the 13.4-13.5 range i'd imagine and possibly a shift kit would fix that. whatever is "wrong" is probably in the first 500' of the track, probably suspension or tranny related.
Old Sep 18, 2006 | 05:03 PM
camzaro28's Avatar
well u did trap 112, then 109. so the pressure could of been low. but that is a really good 60ft, that couldve eatin up some on the MPH.
Old Sep 18, 2006 | 05:50 PM
MTBeni's Avatar
I can't speak for the N2O, but NA the mph seems ok. Its all in the track elev and weather. Check to see if you have knock retard during your runs (I did even with a stock tune). Hope this helps. BTW, I WISH I had your 60fts
MTBeni's Avatar
Old Sep 18, 2006 | 05:59 PM
mattybz28's Avatar
It's called drag radials.
Old Sep 18, 2006 | 07:14 PM
2000GTP's Avatar
Headers will probably help quite a bit as well. High 11s shouldn't be a problem.
cmsmith
Sep 14, 2015 09:09 PM
FryedClutch
Sep 1, 2015 08:24 AM
RobFlag
Aug 29, 2015 11:40 PM
WPHIG2
Aug 27, 2015 06:37 AM
Aug 17, 2015 09:50 AM
