New Personal Best
Old Nov 19, 2006 | 09:17 AM
Ray@NitroDaves's Avatar
New Personal Best
I have been trying to get the suspension dialed in to be able to launch on the bottle. The last 2 times at the track I have been cutting 1.59-1.60 60's on motor and 1.6-1.7 on the jug.
This wwekend we packed up and went to San Antonio Raceway for the F-body vs Mustang Shootout. The only change to the car was increasing the LCA angle.
First pass was NA
1.6008 60' dead hooked...no spin, shudder, just left
4.6565 330'
7.2423 1/8 ET
94.28 1/8 MPH
9.4879 1000'
11.3859 1/4 ET
119.08 1/4 MPH
For qualifying it was time to open the bottle. Set the progressive to zero delay and full activation on launch. But only had 900-950psi in the bottle
the car responded with
1.4991 60'
4.3251 330'
6.6982 1/8 ET
103.78 1/8 MPH
8.7445 1000'
10.4812 1/4 ET
129.91 1/4 MPH
The car picked up .904 seconds and added 10.83 MPH on a 150 shot
For the next pass I got the bottle up to the proper 1050 PSI
1.5719 60"
4.3850 330'
6.7430 1/8 ET
104.38 1/8 MPH
8.7767 1000'
10.5057 1/4 ET
130.74 1/4 MPH
All in all had a good trip to the track as I set new PB for NA 1/4 MPH, and all NX times.
Old Nov 19, 2006 | 11:26 AM
2000GTP's Avatar
Very nice.
Old Nov 19, 2006 | 11:38 AM
Bersaglieri's Avatar
Sweet times, whats the mod list on that bad boy.
-Dustin-
Old Nov 19, 2006 | 05:32 PM
Factory Options:
T-tops, PW, PL, CD, Ebony Leather, T-56
Exterior Modifications:
SunCoast Ram Air Hood
Interior Modifications:
6pt Roll Cage, Corbeau Race Seat, 5 Pt Harness, Custom NItrous Switch Panel.
Performance:
Induction:
Suncoast Ram Air Intake, Stock MAF w/NX MAF Ends, BBK 58mm TB, GTP Ported LT1 Intake Manifold.
Fuel System:
Walbro 255 Intank Pump, NOS Inline booster Pump, FMS 42# Injectors
Engine:
396cid Shortblock
Ross Pistons 12.2:1 CR
Eagle H-Beam 6" Rods
Eagle 3.875" Crank
4 Bolt Splayed Main Caps
GTP Ported LT1 Heads 270cfm Intake/195cfm Exhaust
LaZer Custom Grind 246/254 .613/.590 112lsa
Exhaust:
Jet Hot 1.75" Long Tubes, 3" True Duals w/X-Pipe, Bullets, Turn Downs
Suspension/Chassis:
Front:
QA1 12 Way Shocks, QA1 275# Springs, No Front Sway Bar
Rear:
Stock Shocks/Springs, Billet LCA w/Heim Joints, Spohn TQ Arm, Spohn Panhard Rod, Hotchkis SFC's, Airbag RR
Drivetrain:
Transmission:
John Goebel Constant Velocity/Pressure 700r4, Cryo'd Internals, Goebel 10" 3200 Stall, B&M Cooler
Rear End:
Moser 12 Bolt, 33 spline Axels, 3.73's, Posi
Electronics:
Power Adder:
NX MAF Kit, Purge, NOS Mini Progressive Controller, 860 Bottle Bracket/Heater, NItrous Outlet Center Hump Mounting Bracket, SHO NItrous Line
Old Nov 19, 2006 | 06:08 PM
marshall93z's Avatar
Nice!
Old Nov 19, 2006 | 07:10 PM
CamaroRacing12's Avatar
any pics? or vids? and did u place in this event?
Old Nov 19, 2006 | 07:16 PM
MeanGreen97Z's Avatar
Hard running car. I love nitrous!
Old Nov 19, 2006 | 07:23 PM
I was the #2 qualifier and then in the first round of elim's..... completed my burn out, purged the kit and the bottle was empty...only had 3 passes on a 10# bottle ...needless to say I lost.
The #3 mustang was running 9.9's...#1 ran a 8.50 in qualiying
should have some pics and video later in the week
Old Nov 21, 2006 | 10:43 PM
finnally got some pics
Old Nov 22, 2006 | 08:25 AM
Sweetred95ta's Avatar
Nice times. Awesome pics, too.
Old Nov 22, 2006 | 08:36 AM
Z-RATED94's Avatar
Maybe if you had new back tires instead of those old wrinkled ones you could go even faster.
Old Nov 22, 2006 | 10:29 AM
White H/C 94Z's Avatar
Thanks for the new background.
Nice car and nice times. props to ya on the work.
Old Nov 22, 2006 | 10:46 AM
MEAN LT1's Avatar
Looks like she riding out. Looks at the rears wrinkle up!.
Old Nov 22, 2006 | 11:01 AM
that is mine also
cmsmith
Sep 14, 2015 09:09 PM
FryedClutch
Sep 1, 2015 08:24 AM
RobFlag
Aug 29, 2015 11:40 PM
WPHIG2
Aug 27, 2015 06:37 AM
Aug 17, 2015 09:50 AM
