new opti and still dont start
Old Sep 29, 2012 | 10:24 PM
javi805's Avatar
i got a problem here and need some help.. i cannot figure out what is wrong with the car,, i got the code p1371 so i check the wiring and they all looked good. so i changed the opti spark. once i installed it, it turned on fine then all of a sudden it shut off and the check gauges light came on.. i cannot figure out what is wrong at all.. please i need your help!!!!
Old Sep 29, 2012 | 10:55 PM
Re: new opti and still dont start
What brand Opti? Did you loc-tite the rotor screws? Did you examine the harness connector for corrosion or a bent pin? Did you check again for codes?
Old Sep 29, 2012 | 11:08 PM
javi805's Avatar
the opti was the accel and yes i did loc tite the bolts.. i just got it today.. and i did check the harnss and it was all good... yeah i got the p1371 again after it shut off i was thinking i need a new ignition control module
Old Sep 29, 2012 | 11:20 PM
P1371 code sets for the low resolution pulse in the Opti, not for the ICM.
Old Sep 29, 2012 | 11:23 PM
javi805's Avatar
damn so i guess i have to get a new one then. At least i have warranty for it ill get it tomorrow.. thanks for help man..
Old Sep 30, 2012 | 09:54 AM
You did clear the codes after you installed the new Opti?
Check the harness again. Look for a blue-green corrosion on the pins.
Old Sep 30, 2012 | 12:49 PM
javi805's Avatar
Yeah u know what I did recheck the,harmess and it was,all messed up peeling copper to copper It was causing a shortage which messed up the new opti. ..
Sergio
Jan 27, 2016 04:27 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
