New opti still #3 wont fire
Old Oct 2, 2004 | 10:24 AM
Wildwill2855's Avatar
New wires and plugs, what the hell will cause this same cylinder not to fire? Its just this one, all the other header tubes are hot and this is the only cold and i pulled another plug and it was dry, #3 is still soaked with gas?
Old Oct 2, 2004 | 10:53 AM
Dave89IROC's Avatar
Re: New opti still #3 wont fire
is the wire to #3 good?
swap plugs, or put a new in #3
check fuel pressure, if it bleeds down after you shut the car off, pull the rail loose from the intake and turn the key on, see if #3 inj. is spraying fuel
check compression, pull #1, 3, and 5 and check them one at a time, they should be close, post back with the results
Old Oct 2, 2004 | 10:57 AM
ive tried that didnt help, theres gas on both the spark plugs when i pull them i tried 2, so i know its getting fuel.
Old Oct 2, 2004 | 11:11 AM
Decided to pull the valve cover guess what i see,,,, THE INTAKE RR WAS OFF THE VALVE WITH THE PUSHROD JUST SITTING THERE> THINK THAT COULD CAUSE IT lol
Old Oct 2, 2004 | 11:32 AM
It Runs Now After I Bought A Opti That I Didnt Need Lol But It Was ()k So Why Not Thanks For , Morle Of This Is Check Your Rr
Old Oct 2, 2004 | 12:02 PM
i noticed when i tap the gas to rev it idling, the rpms drop a little then rev up like its hesatating but then it does it, im going to run it down the street and see how it acts.
Took it down the street and it was kinda hesatating, it would give it a little gas and it would make like a poping sound im not for sure, im going to check all my wires and make sure there all the way on the opti.
KYWes
Jun 14, 2022 06:52 AM
88IROC_Z
Jul 22, 2015 11:38 PM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
