New opti, plugs, wires, w/p, maf, not connected, car won't start.
Old Jun 23, 2007 | 01:23 PM
97ws6togo's Avatar
I have a 97 ws6. I put a new gm opti, wires, ngk plugs. I did line up my opti to fit dowel. Car won't start, just cranks. Car hasn't run for at least 3 weeks. I don't have the w/p, the maf and air intake elbow connected. Will these things not connected cause the car to not start? I did see a old post reply from shoebox on something similar saying to plug the maf and elbow back on. Tanks!
Old Jun 23, 2007 | 02:23 PM
mrmint69's Avatar
Why did you replace them in the first place? It will help to see if something else was wrong and still is. I have read a few posts that people had trouble starting if they left stuff off. Maybe double check the connections, plugs, wires and routing to be sure. Hows your battery charge?
Old Jun 23, 2007 | 04:30 PM
SkiBumDreams's Avatar
on multiple occasions my 95 wouldnt restart without the temp sensor in the w/p connected
Old Jun 24, 2007 | 12:40 AM
97ws6togo's Avatar
Well the car was throwing codes for multiple misfires, evap system flow during non purge, and catalyst below efficiency. I mainly decided to change the opti due to water pump failure, so while i have the pump off might as well. I bought the car last august and who knows the last tuneup/opti. Car has like 125,000k. I did find out if the maf isn't connected the car wouldn't start. And also possibly if the temp sensor isn't connected. Thanks guys for your input..
Old Jun 24, 2007 | 12:03 PM
NemesisLT1's Avatar
I had the problem with the MAF and intake not being one, not starting.... freaked me out for a whole day.... as i was ready to give up i put it all back together... funny day...
Old Jun 24, 2007 | 09:54 PM
97ws6togo's Avatar
haha. yours may be funny, but after hooking up maf and temp sensor, still doesn't start. hmmm. i did drop my temp sensor in the bucket of coolant and didn't pull it out for like a week. It could be bad now. Maybe the coil, i'll double check connections as i checked wires again. Perhaps the opti isn't lined up like i thought for sure. Hmm, defiinitaly getting my education.
Old Jun 24, 2007 | 09:55 PM
97ws6togo's Avatar
I know i should check spark. So that will be the agenda for tomorrow.
Old Jun 24, 2007 | 10:15 PM
goblue9976's Avatar
First thing to check is the opti connector. Mine was doing the exact same thing yours was, and the connector was messed up. Definitely check that out, and then go from there.
Old Jun 25, 2007 | 01:57 AM
97ws6togo's Avatar
Haha. Well it turns out i didn't have the harness to the coil plugged like i thought. Car started right up! Seemed a lil slow on idle but seemed like it was picking up before i shut it off. THis is great news. I'll check it more later. Let it run again a little bit before adding water pump. Thanks for the input.
Old Jun 25, 2007 | 08:31 PM
redneck01's Avatar
also try the crank position sensor just to be safe
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
