new opti now timing to high?
Old Dec 8, 2007 | 03:46 PM
30th6's Avatar
just installed a new opti now my car runs rough.it idels rough and the valves chatter on a load it seems like the timing is to high is that possible?
Old Dec 8, 2007 | 05:00 PM
Stl94LT1's Avatar
What brand opti did you install? The MSD unit has a timing adjustment screw.
Also, check for crossed spark plug wires.
Old Dec 11, 2007 | 07:35 AM
30th6's Avatar
its a brand new acdelco from allignition on ebay the wires are'nt crossed done checked.
Old Dec 11, 2007 | 04:40 PM
SweetZRag's Avatar
On an ACDelco unit, there is no adjustment so if the timing is off, you have the new unit indexed wrong. You'll need to remove it and reinstall.
Old Dec 13, 2007 | 07:43 AM
30th6's Avatar
you cant index it wrong it only goes one way.
Old Dec 13, 2007 | 10:05 AM
Actually, with a bit of pressure, you can push the dowel into any one of the three holes. It is a very common problem.
But.... the cam would be 120 deg off with a one hole offset, or 240 crank degrees, so it probably wouldn't even start if it was that far off.
Old Dec 13, 2007 | 11:14 AM
SweetZRag's Avatar
I didn't notice his model year. For my 94, we all know it could obviously be off just a little if it is forced on. My bad.
Old Dec 15, 2007 | 02:20 PM
30th6's Avatar
im sending the opti back i hope its the problem.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
Jan 23, 2015 01:13 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
