New opti, now stumble at idle?
Old Nov 4, 2003 | 02:42 PM
ZZtop's Avatar
I just replaced my opti and I have a slight stumble at idle now. It was not there before, and my wires are not burnt. I have checked and checked them to make sure they are clicked on all the way, but the one on the bottom of the opti (passenger side) is so hard to get on there. I cleaned the connection on the coil as well, cause it had some slight corrosion on it. I guess my question is, is it possible for a slight miss, like a wire not clicked on fully, so only show up at idle? If the car is stopped and ideling, I can see the shifter shake a little and can feel it very slightly in the steering wheel as well. However, if I rev the car it disappears immediately. Is is possible this problem was there before and my old opti was masking it, and what would cause this? I know, tons of questions, but I just cant get is fixed.
Old Nov 4, 2003 | 02:47 PM
Fastbird93's Avatar
I could see a not quite completely connected plug wire being the culprit, but it's also not unheard of for an opti to have problems right out of the box.
Old Nov 5, 2003 | 10:55 AM
ZZtop's Avatar
ttt
Old Nov 5, 2003 | 01:34 PM
ZZtop's Avatar
Just messed with the car somemore, the problem is still there and I have basically ruled out plug wires ( I am sure they are all clicked on). Now what?
Old Nov 5, 2003 | 01:41 PM
rollinn95z's Avatar
Sure all your harnesses going into the opti are snug too?
Old Nov 5, 2003 | 01:43 PM
Hyperspeed97z28's Avatar
get it on a scanner.. I have a stumble at idle too. car runs like a raped ape otherwise....
Old Nov 5, 2003 | 09:02 PM
ZZtop's Avatar
Harness going to the opti is snug. Any things that I can test that are typical causes of a rough idle that clears up right away? Thanks for any help guys, it drives me crazy when my baby doesnt run perfect.
Old Nov 9, 2003 | 08:07 PM
ZZtop's Avatar
ttt, did you have any luck fixing your idle Hyperspeed?
Old Nov 12, 2003 | 01:34 PM
ZZtop's Avatar
It seams like the idle is smoother when it is really cold outside (like at night) and rougher when it is warm during the day. Can a bad IAT sensor cause a rough idle and symptoms like this? What about a vaccum leak, like that little rubber elbow on teh throttle body that is old and cracked looking, could it cause this?
Old Nov 12, 2003 | 02:06 PM
grendal's Avatar
A cracked elbow could get unmetered air entering the motor. So yes, it could cause bad idle and a lean condition too! I haven't had this on an f-body, but I had a VW that had this problem. A hidden crack on the intake piece, and it ran like *** for a year before I found that.
-Michael
beltrunner
May 17, 2015 10:18 PM
grgguy
17
Feb 23, 2015 07:57 PM
IRABuss
Sep 7, 2011 09:08 PM
Lions3
Apr 11, 2003 10:55 AM
Dave19yz28
Jan 26, 2003 01:45 PM
