New Opti & No Start - Need Help!
Old Sep 4, 2007 | 03:11 PM
  #31
sam pace's Avatar
Ok, if thats the case then the new opti is probaly bad.
Old Sep 5, 2007 | 08:34 AM
  #32
Colin91Z's Avatar
Just to update, I tried a two different opti harness's on the car in question, still the same problem. So I removed the opti last night and will be getting a new one today. We must have got a bad one
Pretty irritating. You'd think for how expensive these darn optis are, plus the fact of how hard they are to get to, that AC Delco could build the damn things right the first time
I'll be darn sure to plug the next new opti in and make sure I've got spark before I put the water pump on this time
EDIT: Before anyone asks, I did check when I removed the opti... and yes, it was indexed properly.
Old Sep 5, 2007 | 02:37 PM
  #33
Mtxz453's Avatar
i guess people are ignoring my post, i had the exact same thing happen when i ordered my opti from jegs. They are sending out opti's that are totally timed wrong. Call them defective but i went threw 3 of them, all the same thing, before i finally switched to a gm distributer and msd cap and rotor. and now have no problems.
Old Sep 5, 2007 | 02:42 PM
  #34
Colin91Z's Avatar
I wasn't ignoring you...I did not get this opti from Jegs. It IS an actual AC delco opti from the dealer. And it's defective.
Old Sep 6, 2007 | 06:06 AM
  #35
RKHiPerformance's Avatar
Our Opti is a GM unit purchased from Summit.
Old Sep 6, 2007 | 06:18 AM
  #36
SS RRR's Avatar
I'm wondering if the screws in the opti which hold the rotor are loose.
Old Sep 6, 2007 | 06:36 AM
  #37
In our case, I removed the distributor cap and Lock-tited the rotor screws before we installed the new Opti. I did this based on advice I got from this board.
Old Sep 6, 2007 | 08:38 AM
  #38
Colin91Z's Avatar
Ok, I kinda feel like a retard
Got to messing with the car again last night, and found that the white wire that goes to the ICM in the driver's side wire loom had been cut to splice in an aftermarkert tach by the previous owner. Well, when he sold the car, he removed the tach...aparently very quickly without regards to the wire that it was attached to
So after I found the severed wire, we quickly sodered it back together and heatshrinked it, put the opti back on (yes, the same opti that I thought was defective ) and buttoned up the rest of the motor....and then....
...Man that Joe O cam thumps nice
Old Sep 6, 2007 | 09:10 AM
  #39
SS RRR's Avatar
Is it possible to put the rotor on wrong? I've never taken an opti apart so I honestly don't know.
Old Sep 6, 2007 | 09:27 AM
  #40
Colin91Z's Avatar
There's a dowel on it, so you can't put it on wrong. On the GM units anyways. I can't speak for the aftermarket optis though.
Sergio
Jan 27, 2016 04:27 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
