New Opti, ICM, Coil, Stater, Wires, Plugs, still NO start
Ok I did learn alot about my LT1 during this time. I have owned 5 LT1 F-Bodies and this is the 1st one ever did so much work on myself. Anyway I have a new opti,starter,ignition control module,plugs wires,battery and it still wont crank over. I also cleaned all the grounds and fusible links and everything with battery cleaner solution and nada. Sometimes it feels like its going to crank over but it never does. Also the lights dim/flicker when i'm trying to start her up and when its trying to crank i hear like a wierd noise sounding like metal grinding metal. I really dont want to have it towed to a dealership but i havent driven her in a good 5 months and im getting desperate. Just been putting alot of miles on my 2001 SS which I hate doing. At this point im ready just to put my fist thru the window but i do love the car. Any help would be appreciated
Re: New OPTI,ICM,COIL,STARTER,WIRES,PLUGS still NO start!! i give the hell up..
Originally Posted by Taintedz28
alternator maybe?
CJMatt
I will try that in the morn. Thanks
sounds like you replaced alot of parts........but did you trouble shoot the problem?????? Do you even know if your still getting spark??? is the ECU alive???? hows the fuel pressure????
battery fully charged?
did the snout break off the starter....it happened to me and i had the same symtoms as you.
try running a wire straight to the starter and see if that works.
had a 94 burban, the bearings in the altenator fried on the wife one night,She thought the brakes were smelling, next morning, it just barely turned over and had a grinding sound..wouldn't start. as CJMATT sugested, take off the belt and give it a try...
Atomatic or standard?
What lead up to it not wanting to start...
1971 Camaro, roller cam 454 LS6, tremec TKO 600, 2.56 gears, berlineta t-top, New Mexico plate "RAT454"
You said it won't crank over. As is you turn the key and nothing?? Provided the battery isn't dead (we've all been there at some point) have you thought about the ignition switch or vats being an issue?? Is it throwing a security light or anything (if not would kinda rule out vats).
After re-reading your post, see if you can turn the motor over by hand to make sure it's not seized. You can battery direct jump the alternator to make sure it's engaging properly also. Could be the solenoid on the starter, could be a bad battery if the lights are taking a major dim (I went through that, battery would show a charge but almost completely discharge when the ignition was keyed).
Hey everyone
Well to answer some of the questions. I didnt check fuel pressure.That is something i need to do. When i put the key in and turn the security light doesnt stay lit. The Battery is new but to rule out a battery i did try the one out of my SS same deal. The Starter is new. Also i owned a Lt1 Z that the igntion switch went dead on. That car the nothing happened when i put the key in and twisted so i kinda ruled out that.
Fastbird93,
How are you liking the vette? Glad to see you are ok. I havent talked to you since before the war in Iraq. Wanna take a drive down to AC and help me push this car in the bay cause its pissing me off
Fastbird93,
Hey, the Vette is great. I love it every time I get behind the seat.
If you want, I can try to swing down to A/C sometime and see if I can't help you out. You're only about 40 minutes away from me, and I could use an excuse to hit A/C up with the wife.
LOL yea if I dont get this figured out by Tuesday Im going to get raped by the dealership because Im going to end up spending cash to get it towed and fixed by them
Well, I got nothing going on between now and tuesday other than zaino for the Vette and scanning a buddies car, so if you want a hand let me know.
If you know whats up by all means do it yourself....but i wouldn't call it a rape when your baffled.
Originally Posted by hey01
well if the dealership replaced your opti ICM COIL PLUGS and WIRES, and your car still didn't run..........you would have gotten all those parts for free...instead of spending the few hundred bucks that you did. Sometimes its better just to get it off your back and done with then to shotgun expensive LT1 parts at it.
