New Opti = 90% how do i get to 100%?
Old Jul 22, 2006 | 06:54 PM
93transam1234's Avatar
Got a new opti on and it took care of most of my high rpm stumble, and the car is alot smother through all the rpm's.
Also got a new ICM a few weeks ago (didnt notice any difrence.
Now i have a small stumble still left, i guess i could try a new coil and wires. Wich one os more likley to cause a small stumble in high rpm's?
BTW took the old Opti apart and it had corrtion on all the posts of the cap and on the rotor, i scraped off the corrotion from the post and it had eat half wat through the post .
A little more work and i think i will finally have my car at 100% and ready to put in my stall converter and then NAAAAWWWWWS
Old Jul 22, 2006 | 08:29 PM
Robs97Z28's Avatar
Re: New Opti = 90% how do i get to 100%?
If, your cap and rotor are in that bad of shape. I would say, you need to replace your plugs and wires..
How many miles are on the clock?
Old Jul 22, 2006 | 08:40 PM
THe opti had about 140K, wires and coil have 1 year (maybe 10K)
Was the damage to the opti done by bad wires and or coil?
Old Jul 22, 2006 | 11:16 PM
Normal wear and tear. They don't last forever.
Old Jul 23, 2006 | 12:13 AM
dannyum89's Avatar
Change the plugs and wires. My car had MSD wires on it from a previous owner and they made the car stumble quite a bit under accelaration. I found Delco's to be the best. They are not as big but they handle the heat better. I changed the wires and plugs and all hesitation and stumbles went away.
kxrawx
May 25, 2015 08:29 PM
*Emilia*
May 13, 2015 09:05 AM
nikolt1
Feb 27, 2015 09:10 PM
