New oil pan gasket
Old May 20, 2011 | 09:10 AM
Z28-50's Avatar
New oil pan gasket
Ok I'm going to put on a new oil pan gasket. A Felpro 1 piece.
Do you still use silicone where the corners of the pan meet the front cover and rear main oil seal and 1 inch up the ends of the arches on the front cover and rear main seal housing.
Reason I ask is a note in the gasket pack states install dry no adhesive.
Charlei
Old May 20, 2011 | 10:05 AM
my1994z28's Avatar
Re: New oil pan gasket
Yes,you put RTV on all 4 corners,the sides of the timing cover and rear main seal.
Old May 21, 2011 | 12:55 PM
MachinistOne's Avatar
Yep - they will leak if installed dry.
Silicone in the corners and up over the curve of the seal adapter and timing cover, then lay the seal in place, then again with the silicone in the corner and up over the curve on front and rear.
Old May 21, 2011 | 03:53 PM
RamAir95TA's Avatar
I've never had an oil leak and I've always installed them bone dry...just saying.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
