new o2's...code 13...accelerate like ****...after lt install
Old Jul 28, 2003 | 12:50 AM
superal's Avatar
The car hasnt ran right ever since the lt install. It will barely start and will not idle at all. I drive it and it will not accelerate worth ****. It is like I'm wot in 6th gear at 40 mph...abotu how fast I can accelerate. I just put in brand new ac delco o2's. Brand new o2 extension. Everything related to a lt install is brand new. I cannot figure out what could be wrong here... oh it throws a code 13 every now and then but it goes away and comes back...
Old Jul 28, 2003 | 12:53 AM
96z's Avatar
96z
Hmm vicous header leak? Bad O2 connection. A stupid question but did you plug up all of the oil AIR and EGR stuff.
What does code 13 stand for?
Old Jul 28, 2003 | 01:01 AM
superal's Avatar
Well it could be a viscous header leak but the damn thing wont idle so I cant get out and feel around the headers for leaks. I need to check for continuity at the o2's to see if that is a problem. I plugged up the 2 holes in the back of the intake and my headers dont have emissions so I didnt have to plug those.
I just took out the a/c and intalled the delete pulley if that helps. I just ripped out all the lines up to the light green box up under the cowl and did nothing else. Did I forget something for the a/c removal?
New ovc plug wires. Positive they are wired right. I'm just dumbfounded as to what is wrong here...
Old Jul 28, 2003 | 01:11 AM
Blue96z28's Avatar
I have'nt read all the posts in here, so i maybe repeating or soemthing, just wanted to put in a little input. First I would say that it would be something emissions related since you removed it all.....BUT that could never cause the problems as drastic as you say they are, so honestly i think it is a problem with one of the o2's. Either the extenion is bad or something, but maybe its in harness, or a burnt wire. Do you have a scanner? COuld you check to see the o2 reading if you get a chance?
Old Jul 28, 2003 | 01:13 AM
superal's Avatar
Don't have a scanner but wish I did. And yes, the problems are not exagerated. My car will go 0-60 mph in about 30-40 seconds wot.
Old Jul 28, 2003 | 02:18 AM
96z's Avatar
96z
Jeez, what all did you take off when you did the headers. Why wont the car idle? What does it do?
Old Jul 28, 2003 | 07:17 PM
superal's Avatar
The engine will turn over and over but not fire up without depressing the gas pedal. When the pedal is depressed while I crank it, it will fire up after 5 or 10 seconds and maybe give me a loud pop (backfire) every once in awhile. It runs somewhat smooth but absolutely will not idle, it just dies. So I took it for a spin and it was just slow as ****. It will rev up pretty good while not under load but as soon as it's in gear and I punch it, it just doesnt go.
I took off the egr, air, and the a/c. I plugged 2 holes in the back of the manifold for egr. I left the solinoid as is and plugged in. I left the 2 barbs on the solenoid open. Maybe the solenoid is f'in me over?
I ripped out everything relating to the a/c up to the green thing under the cowl on the passenger side. I installed the a/c delete pulley.
I installed taylor ovc plug wires.
New ac delco unheated o2's and an extension for the passenger side (the driver side reached without an extension).
True dual 3" x-pipe exhaust ending with bullet mufflers before the axle. There is a slight leak at the collecter to exhaust joint on the passenger side.
This is all I did and the car's been out for 3 weeks for a freakin header install. Help!
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
