new and need help!
Old Aug 3, 2010 | 11:19 PM
  #16
boyd95ss's Avatar
Ok, after I posted last I went and did some research on the intake but I didn't find that picture, in the picture on right, what goes on the nipple above the fpr hose?
Turns out I had the fpr hose on top, switched it and no change, I'm going to bed now but I'll mes with it some more tomorow
Old Aug 3, 2010 | 11:29 PM
  #17
The vacuum hose for the HVAC controls - "G" in this diagram from Shoebox:
http://shbox.com/1/hvac_vacuum.jpg
Old Aug 3, 2010 | 11:31 PM
  #18
RamAir95TA's Avatar
One is for the FPR and the other is for the vacuum check valve located near the PCM (junction of 2 other vacuum lines).
Old Aug 5, 2010 | 10:51 PM
  #19
boyd95ss's Avatar
new fuel pump: check
running engine: no check
ahh!
Old Aug 6, 2010 | 05:45 AM
  #20
Guest47904's Avatar
Guest
Please refer to post number 10
Old Aug 6, 2010 | 10:58 PM
  #21
boyd95ss's Avatar
thought a video might help
hope it works
Old Aug 10, 2010 | 07:29 PM
  #22
boyd95ss's Avatar
just an update: i replaced the fuel pressure regulator because of the eratic nature of the fuel pressure, it is now holding constant at 42pds while running, but it is still running the way it was in the video
i still have not checked for compression, it is showing a check engine light, but since it is an obd1 computer port the reader is $175, trying to find a way to avoid buying one for a one time use, and i cant exactly move my truck in its current state
Old Aug 10, 2010 | 11:51 PM
  #23
IceMatrix69's Avatar
I may have missed it earlier in the thread but have you pulled plugs and taken a look and what they look like? Fouled possibly......
Old Aug 11, 2010 | 08:52 PM
  #24
boyd95ss's Avatar
plugs are brand new,
got icm tested and the low rpm side was bad so i guess i found the problem
