new MSD opti cap and coil any good?
Old Feb 15, 2005 | 04:29 PM
blackztpi's Avatar
got my new summit last week and noticed msd makes a new cap and rotor kit for the lt1 optispark. vented, and nonvented versions available. just wondering if anyone has any input on this product? sells for $150.00
Old Feb 15, 2005 | 04:30 PM
neil350's Avatar
Re: new MSD opti cap and coil any good?
To little, 8 years to late. Theres been some talk about this in a couple of the posts.
Old Feb 15, 2005 | 05:51 PM
blackztpi's Avatar
so is it any good or not?
Old Feb 15, 2005 | 06:29 PM
fesgali's Avatar
I don't think to many people have tried it. With the coil kits around they are a little late making it. If they would have made a whole opti unit to go with the cap and rotor and able to sell it for $200 they would have actually made somethin.
Old Feb 15, 2005 | 06:42 PM
Not enough data, yet. Plus, some sources say they are back-ordered.
Even after people get them on their car, it will be many miles down the road before anyone knows if they are worth anything. I would say it would be at least a year before there is any decent data out there.
Old Feb 15, 2005 | 06:57 PM
The Engineer's Avatar
I noticed the "new" MSD cap and rotor for the LT1 opti distributor and was also wondering if someone had used it? One thing for sure, MSD makes high-quality products, so it should be good.
In the past when you had LT1 optispark distributor problems, your only option was to purchase a complete GM replacement distributor at about $270. However, we now have another option to buy the MSD cap and rotor at $150. So, with the new MSD items we can now rebuild the optispark distributor. Maybe it will hold-up better with the MSD cap and rotor!
I'm planning on installing the GM LT4 roller timing chain and gears on my LT1 in a few weeks. And, while I have it apart, I'm going to use the MSD cap and rotor to rebuild my opti. So, I've already decided to use the MSD cap and rotor, unless I hear something bad.
Old Feb 15, 2005 | 08:19 PM
neil350's Avatar
This is just a cap and rotor not the comeplete unit though, keep that in mind.
Old Feb 15, 2005 | 08:46 PM
There has always been the option to buy just a cap and rotor, just not one from MSD. GM has always sold the cap and rotor kit. Aftermarket ones have been available, too.
Old Feb 15, 2005 | 08:56 PM
Mtrhds94Z's Avatar
Wells makes the caps, but I could never find one... they also make a good cap [brass contacts instead of aluminum, etc]
Old Feb 18, 2005 | 12:21 AM
blue's Avatar
I just wasted an hour searching the internet for a Wells cap and rotor. I found their website and it's about the worst I ever saw. They have no links to anyone who sells their products, the only link on there that might help is dead, and the comment form (which I tried to use to tell them their website sucks and that I won't be buying their product since I can't find it) doesn't work. I sent them an e-mail instead. I would just get the MSD but it might be a good while before it would get here, while my car with new headers is running awful because of the opti.
Old Feb 18, 2005 | 01:59 AM
Here are some additional thoughts on the optispark and MSD cap and rotor issue. If you are having optispark problems (bearings worn, photo emitter/receptor module bad), or have extreme high mileage (100K +), your best course-of-action would probably be to replace the complete distributor with the GM (OEM) replacement at $270+.
However, if you are not having any problems (other than cap & rotor), have low mileage and just want to freshen-up your optispark, the MSD cap and rotor would be the way to go at $150. Also, I haven't checked on the availability of an OEM, or aftermarket cap and rotor, other than the MSD. I do like MSD products.
1997 Silver Z/28 LT1-Auto
w/ 30 th Anniversary navy blue stripes
Kooks Long-Tubes w/ Off-Road Y-Pipe
Crane 1.6 Roller Rockers, K&N Air Intake,
Hypertech Performance Program,
Aluminum Driveshaft and a few undisclosed
upgrades.
Old Feb 18, 2005 | 06:55 AM
moparman's Avatar
I think Autozone might have the Wells. Look up the distributor, on Autozone's site, for an LT1, and see if it isn't a Wells.
Old Feb 18, 2005 | 09:17 AM
GREGG 97Z's Avatar
I just saw an a big ad for this in the latest GMHTP I received yesterday, I was wondering what the price was, $150 sounds pretty reasonable for what it is. When it comes time to tear back into the motor for a cam upgrade or anything else down the road I would likely go with it, Ive never had any problems with my original opti but as mentioned it would be good to freshen up an older opti. I wouldnt expect any increased performance from it though.
Old Feb 18, 2005 | 11:05 AM
mmmchickenboy's Avatar
Autozone has the Wells cap/rotor kit for $131.99 and CSK&AA stores have 4 different cap/rotor options: GP Sorensen ($132.88), AC Delco ($168.88), Borg Warner ($190.99), and Niehoff Ignition ($169.99).
Old Feb 18, 2005 | 04:46 PM
Mtrhds94Z's Avatar
My post wasn't a plug for Wells, just saying that others than GM makes them..
I never did find one locally[ no Autozones around here] but the way I did find out was I emailed their engineering dept when I first got the car[5+ yrs ago]
Here's the p/n's they gave me:
Cap & Rotor Kit Wells DR 2032 unvented [DR 2026 vented]
Never did get one, so can't say good or bad, but any others I have used are red, with brass contacts.. [not even positive that the p/n's are correct but they were gotten from Wells]
