new motor question
Old Sep 12, 2008 | 07:51 PM
94formbird's Avatar
Unhappy new motor question
I just finished installing my 355 blown motor into my 94 firebird. My question is I also put a 3200 stall tc in, without a tune would it rev up high before it started to move the car , or is it just the tc?
Ryan
Old Sep 12, 2008 | 11:35 PM
mpe331lx's Avatar
The Torque converter will cause the rps to rev a little higher befor the car starts to move compared to stock. even though you have a 3200 stall converter, it should not get even close to 3200 to get the car moving. 3200 is supposed to be the maximum that the converter will flash to when the car is bieng held back and under full load (trans break or break torquing).
How high does it rev before the car moves?
You probably need a tune also. What is your combo?
Old Sep 12, 2008 | 11:45 PM
94formbird's Avatar
Probly around 2000. Ported heads, intake. Fully forged 355, -18cc je pistons. 577/577 on 234 dur cam. Lt,ory,no cat no emissions. .373 rear gears. Sounds strong but just won't go, and I don't wanna blow anything up not going anywhere lol
Old Sep 13, 2008 | 07:02 AM
mpe331lx's Avatar
Originally Posted by 94formbird
Probly around 2000.
Sounds about right for a 3200 stall. Thats the nature of the beast. Make sure to get it tuned before beating on it.
Do you have larger injectors? Is it tuned at all?
Old Sep 13, 2008 | 06:04 PM
94formbird's Avatar
30lb injectors, no tune yet
Old Sep 14, 2008 | 10:16 AM
2000GTP's Avatar
I probably wouldn't be driving it around until you get it tuned for the bigger injectors.
Old Sep 14, 2008 | 10:18 AM
94formbird's Avatar
I havnt really been driving it around. Just up and down the driveway
Old Sep 14, 2008 | 12:43 PM
mpe331lx's Avatar
I would only start it if you HAVE to. Yo will foul the plugs pretty quickly. If it is too rich you can also wash out your rings and cylinder walls, which is bad any time, but especially bad on an engine that is not broken in yet.
GET A TUNE!
Old Sep 15, 2008 | 06:20 PM
lt1-xjs's Avatar
check the trans fluid, it may be low.
Old Sep 15, 2008 | 06:22 PM
94formbird's Avatar
That's what's coming this weekend. Filter ans fluid change
Old Sep 15, 2008 | 10:47 PM
87bandit's Avatar
this is a lockup convetor correct?
Old Sep 15, 2008 | 10:50 PM
94formbird's Avatar
Yes
Old Sep 15, 2008 | 10:52 PM
94formbird's Avatar
Yes.
Got it in today, did a powerbrake, broke the tires loose at around 2000rpm. Musta been in my head, although it does feel a little loose. Filter and fluid change shouldn't hurt.
Chris Anderson
Jan 27, 2015 08:30 AM
ChrisFrez
Jan 18, 2015 08:05 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ChrisFrez
Nov 23, 2014 10:33 AM
