New motor having problems starting
Old Aug 24, 2004 | 10:13 PM
DrewHMS97SS's Avatar
Just a basic run down:
1st time I tried to start the motor, as soon as I touched the neg side of the batt, it would try to turn over by itself.
2nd time, I turn the key (after switching the 2 eyelets by the starter, car no longer tries to turn over by itself) i get nothing, just the fuel pump on msd 6 on, nothing from the starter.
Any ideas? Anything helps.
Old Aug 24, 2004 | 10:32 PM
lillbush5555's Avatar
Re: New motor having problems starting
Does the motor turn over? Does the starter move? If not might need a new starter. Take it to azone and have it tested.
Matt
Old Aug 24, 2004 | 11:45 PM
Matt
the starter doesnt do anything. i just replaced the starter yesterday after breaking the stud off of the old one.
Old Aug 25, 2004 | 12:02 AM
RMC's Avatar
RMC
You might have had it on the right one the first time but it was angled so that it was touching both posts. Seems like that would cause what you described but then when you switched them you get nothing now. Might want to just try switching it back but double checking that it's not touching another connector or post thing.
Old Aug 25, 2004 | 09:35 AM
good idea, ill check that first thing today.
Old Aug 25, 2004 | 12:37 PM
got the beast started, only to find out a min or 2 later there was 2-3 qts of oil on the ground. the oil is coming fromt the back, and looks like its in the bell housing. if you go here you can see the 3 plugs in the back of the block. im really at a loss on this one. oil sending unit behind the intake is cherry, the plug is in above the oil filter, and its a 1 piece felpro oil pan gasket so i cant see it spewing that much oil in such a short time (2-3 min).
anyways, i think im going to drop the tranny to see wtf is going on.
Alex Barnes
Jan 24, 2015 10:21 PM
HCz28
Jan 11, 2015 11:21 AM
Britbilly
Jan 7, 2015 08:49 PM
1LEThumper
Jul 14, 2003 12:45 PM
