New motor...grinding noise while trying to start
Old Sep 11, 2007 | 12:15 PM
  #31
9formula4's Avatar
you don't need to shim a stock starter. The mounting block is manufactured to be mounted and done with.
Are the teeth on the starter chewed? If so it could be hitting that point and slipping. It also sounds like an arc of some sort is hapeening when your turning it over.
Just bolt it up and have someone turn it over with you under it with the inspection (tranny) plate off. This will allow you to see what is going on when it engages.
Old Sep 11, 2007 | 12:24 PM
  #32
Chevycobb's Avatar
I may do that. I can pull the pcm batt. fuse and that won't let it actually try to fire up right?
Old Sep 11, 2007 | 12:36 PM
  #33
30696bird's Avatar
Right.
On a side note.....if the starter is in some way bad I'm kinda local and I'll give you the extra one I have for the cost of gas to meet you somewhere.
Old Sep 12, 2007 | 06:18 AM
  #34
ta4me's Avatar
Any luck last night Chevycobb. I know you want to drive it soon!
Old Sep 12, 2007 | 10:08 AM
  #35
Chevycobb's Avatar
nah didn't have a chance. too many wrecks in atlanta so traffic was worse than it usually is. try again tonight. I have next week off so I was looking forward to driving this thing soon
Old Sep 13, 2007 | 09:49 AM
  #36
Chevycobb's Avatar
I can't believe it...was it really this simple?? the cable for the theft dterent relay that goes to the starter some how got the insulation split and was touching the pcm ground. cut...splice...moved the pcm ground further away just in case. turned the key and starter turned the motor no problem(had pcm batt fuse pulled). now I just gotta put the exhaust back together and clean up tools to try and fire this thing up soon
Old Sep 14, 2007 | 04:07 PM
  #37
1SlowFormula's Avatar
Glad you got it worked out, it's always the little things that kill you...
Old Jul 20, 2008 | 10:59 PM
  #38
94arcticwhiteM6's Avatar
luckily it really was that simple. your vid helped out a lot cause mine was making the same noise. camaroz28.com has really saved my *** on this project.
Fatdog2
Feb 12, 2015 12:24 PM
warmeck
Feb 5, 2015 11:04 AM
karnykamaro
Feb 2, 2015 01:37 PM
jj71787
Dec 30, 2014 02:15 PM
squarehead
Nov 21, 2014 08:02 PM
