New member:Got valve spring question
Old Sep 6, 2006 | 09:37 PM
96redhotz's Avatar
I have a 96 Z with LT1. Basically stock(cold air intake only upgrade). Putting 1.6 roller rockers in and LT4 hot cam but don't know what springs to use. Don't want to go to radical because it's daily driver and don't want to mod computer. Also, 58mm Throttle body? Will I have to change injectors?
Old Sep 6, 2006 | 10:01 PM
rskrause's Avatar
Moderator
Re: New member:Got valve spring question
No, you don't need new injectors. If you want the hot cam, why not get the whole kit? It's a pretty good deal and comes complete with cam, rockers, springs, retainers, etc.
Rich
Old Sep 7, 2006 | 08:18 AM
SStrokerAce's Avatar
I agree, it is a good deal.
If you are buying used parts (like a hotcam) then there are some inexpensive alternatives for springs.
Bret
Old Sep 7, 2006 | 09:30 AM
Z-RATED94's Avatar
Why would you not have the proper tune if you do go with the cam swap? Even on your car "as is" you would benefit from having your computer tweaked. Do it right and you will be happy with the results. And no, you do not need a larger TB.
Old Sep 7, 2006 | 10:01 AM
OBE1 95Z28's Avatar
No need for a larger TB, the stock 48mm isn't a restriction at your HP level.
Old Sep 7, 2006 | 11:35 AM
RE AND CHERYL's Avatar
Ditto on the TB. You don't need it.
oldschool
Feb 9, 2016 09:21 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
