New MAF?
Old Sep 10, 2004 | 11:21 PM
stone150's Avatar
New MAF?
should i replace my stock gm MAF with a high performance one? is it worth it?
Old Sep 10, 2004 | 11:31 PM
kyzar24's Avatar
Re: New MAF?
i gained 1 tenth and .4 mph with mine im selling it to if interested
Old Sep 11, 2004 | 01:37 PM
96capricemgr's Avatar
Re: New MAF?
There is no such thing as a "high performance" MAF. The job of the MAF is to measure air flow nothing more, what you want is one that does that accurately which leaves unmolested GM MAFS, unless you have the ability to properly tune for a ported/modified which if you did you wouldn't have asked this question.
What the $300 aftermarket MAFs do is report FALSE information to the pcm trying to make it run leaner at WOT than what GM intended, thing is that the pcm learns it is being tricked and compensates, byebye minor power gain IF there was one. You can get more and better results and have them be permanent by reprogramming the pcm for the right AFR, which as luck would have it even costs less.
When combine with air flow enhancing mods the aftermarket MAF frequently cause drivability problems as well since the combination can cause things to get a little too lean(have even heard of one engine failure die to such). Frankly cease taking advise from anyone who tells you to use an aftermarket MAF, they don't know what they are doing.
Old Sep 11, 2004 | 04:55 PM
97FormulaWS-6's Avatar
Re: New MAF?
Exactly what you said...
The only "Upgrade" I recommend, and only if the stocker fails or becomes the main restriction in the intake, is using a GM Z06 MAF, which requires the PCM to be re-calibrated for the new MAF to operate properly.
Old Sep 11, 2004 | 05:30 PM
Re: New MAF?
If a LT1 f-body MAF becomes a restriction than the ZO6 sensor is not going to help, it operates at a higher frequency than the LT1 sensors, the stock pcm can not understand it past about 350gps where it can understand the LT1 f-body one to well over 400gps.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
