new heads.misses after warmed up
Old Jul 27, 2008 | 09:59 PM
x24-7x's Avatar
Ok so the car is a 95 firebird LT1. headers,exhaust,FIPK k&n intake, stage 3 clutch. So i had 3 bent valves so i went ahead and replaced the heads with another set of stock heads along with the lifters. Adjusted the valves 3/4. Seemed to run fine but they were unusually loud so i tightened them 1/4. Went out for a drive and it ran fine until it got hot enough for the temp. guage to move..as it gets warmer it seems to miss worse and worse. I had to replace one of the spark plug wires but it seems to be fine. Any ideas??
Old Jul 27, 2008 | 10:03 PM
x24-7x's Avatar
also..the car has been sitting about 8 months and it throws white smoke out of the exhaust unless its just sitting there idling..the oil was changed about 4 months or so ago and im about to change it again even if it has only been sitting..
Old Jul 27, 2008 | 10:26 PM
x24-7x's Avatar
AND..the rubber peice that goes from my MAF to my FIPK intake...has a really bad tear in it to wear air could leak pretty bad..could the possibly be a problem?
Old Jul 27, 2008 | 10:55 PM
x24-7x's Avatar
AND..when i would accelerate and it was missing..it seemed to pull on the shifter unusually hard..
Old Jul 28, 2008 | 08:42 AM
x24-7x's Avatar
now the car does it when it first starts up to. so open and closed loop. and under any kind of acceleration its really jumpy.
Old Jul 28, 2008 | 09:48 AM
x24-7x's Avatar
sorry to post again but the car also backfires under deacceleration.
it seems to only do it under a load also. just idling it runs fine and it revs fine. but as soon as i put it in gear and accelerate it wants to act up
i went ahead and set the valves back to where they were also..
for everytime it hesitates,which seems like everytime it fires, you can also hear a click like a valve or exhaust leak or somethin..
could this be badly adjusted valves?
i saw somewhere somebody was having close to the same problem and it was a leak around the MAF.but i unplugged the MAF and it runs the exact same..
Old Jul 28, 2008 | 08:38 PM
mad95z's Avatar
you dont want any intake leaks between the maf and throttle body.
check all your plug wires, run the car in the dark and check for arcing/sparks.
It is very important to set the valves/lash in the proper order, and to the proper spec.
If you are not sure if it is set up right, re-adjust the valves. Search this site there are several good write-ups here.
David Dempsey
Mar 12, 2016 12:42 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
greenzee28
Sep 25, 2015 04:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
