New heads on 100k engine
I just installed a supercharger and would love to make the car as fast as possible without blowing it up. I see Trick Flow sell heads made for supercharged car. The manifold has the dreaded rear leak so would this be a good time to change the heads also? Is this good or will i end up with an engine that will have problems? Has anyone done this and how did it go.
my first time.
The blower should be alright ONLY with low boost (i.e. 4-6 psi) and a spot on tune. If you want to do heads and cam however, go for it. I did my heads/cam swap at 94,000 miles. Runs great.
Not really. Its very straightforward. I had mine off in about an hour
my first time.
my first time.
Always gets done right/clean with no issues or leaks.
In any case, like I said, it's an easy job in comparison to swapping heads w/ the motor in the car (not so much that it's not easy, just a real pain in the ***)
As mentioned above, those heads will drop the compression a tad which might not be a bad thing for a forced induction application. However, with a 100K on the clock, I personally would be more inclined to set aside whatever extra funds towards a stout replacement shortblock and worry about better heads down the road.
oldschool
Feb 9, 2016 09:21 PM
