NEW ENGINE STALLS OUT, please help
Old Sep 27, 2005 | 12:30 PM
hot95camZ28's Avatar
I just got throuh rebuilding my 1995 Z28. M6, bored over .020", ballanced, lt4 hot cam w/ 1:6 rr,new lifters, new optispark, accell 300+ ignition, larger mass air, adj. fuel pres. reg., gastket matched heads, bbk shorties, stock injectors throtle boddy and tune.
The car fired up with a few turns of the key and ideled pretty steady until i had to shut it off because it was the middle of the night. Then when i try to drive it the car dies after running for about 1 1/2 - 2 minutes. And wont start unless i let it sit for a couple minutes. Then it will fire back up and die. But it will fire up if it sits for 10 minutes or so and idle pretty good then just die again. i have good fuel pressure, i dont hear any vacume leaks. i was told by a tech that dyno tunes camaros/vetts all day, that my stock computer will run the lt-4 cam no problem. please help, what will make the car die after running fine for a few short minutes????
thanks
Old Sep 27, 2005 | 12:42 PM
Re: NEW ENGINE STALLS OUT, please help
I would start by putting the stock MAF back on.
Old Sep 27, 2005 | 01:00 PM
would that make the car die out? it seemed to run fine w/ the larger mass before the new motor. what would i do if i try that and it still doesnt run right?
Old Sep 27, 2005 | 04:25 PM
Ttt
RUENUF
May 25, 2016 08:10 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Injuneer
Dec 15, 2014 09:36 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
ARFFormula
Aug 3, 2002 09:55 PM
