New Compressor
Old Mar 27, 2004 | 09:34 PM
kleen's Avatar
New Compressor
I pulled my A/C Compressor last fall when the bearing went out and just put on the 1LE pulley. I am going to be installing a new compressor now that it is getting hot again, but I am wondering if there is anything else I should swap out while I'm doing this (drier, condenser, whatever)? Any thoughts?
Old Mar 28, 2004 | 12:11 AM
roadtrip120's Avatar
I just did mine, i had the a/c delete as well.
just FYI
you have to run a jumper wire to the compressor to add freeon. the computer has a low freeon level sensor so, the compressor wont turn on if it is low on freeon. so you have to manualy trun it on the compressor. I bought the conector from Gm, and conected it to the compressor then to the battery , after i added freeon i pluged the factory conector back in.
all cold air now
good luck
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
