New Cam????
Old Feb 25, 2004 | 08:58 AM
Hawk350's Avatar
New Cam????
Hey fellas, if this sounds incorrect, please correct me. I hear that there are cams that are coming out that are ground a bit differently and change the firing order on the engine of 2 cylinders??? Suppose to make the engine run smoother. Question is.....this is supposed to work on carbarated engines but would it work with EFI? Anyone have any info on this please post...
Old Feb 25, 2004 | 11:07 AM
Riddlerlt1's Avatar
I dont see anyways it wouldnt change the firing order.
Old Feb 25, 2004 | 11:11 AM
Don 97 SS's Avatar
A cam change alone won't change the firing order, it just changes the valve positions.
Old Feb 25, 2004 | 11:16 AM
SBCGENII's Avatar
comp cams 4 and 7 swap camshaft. its supposed to create a smother torque cures with only a minmal hp increase if any. . And fuel injected cars are going to have a different grind. So even if it did work the gains would only be worth it if you were in a highly competive drag class.
Old Feb 25, 2004 | 11:32 AM
Hawk350's Avatar
That's exactly what I was tryig to say. Do you know if this works for fuel injected cars?
Old Feb 25, 2004 | 11:48 AM
SVT Killer LV's Avatar
it can, i am looking to do this, but i want some more information on this, there is another thread going on about this very topic, i bumped it last night to see if there was any updates
Old Feb 25, 2004 | 11:52 AM
faded93bird's Avatar
There is a nice thread on this subject in advanced tech.
here
Old Feb 25, 2004 | 12:00 PM
Hawk350's Avatar
Send me the link....I am looking into this too. I am doing heads and cam....looking into a custom cam and this is now an option...need more info on this and if it will work with computer controlled cars.
Old Feb 25, 2004 | 12:58 PM
Hawk350's Avatar
So I guess none carborated cars are out....
Old Feb 25, 2004 | 02:10 PM
SBCGENII's Avatar
i think fuel injected is out but you can always carb your Lt1 if you wanted to be differnt
Old Feb 25, 2004 | 02:24 PM
Hawk350's Avatar
Nahh, I want to keep it injected....and keep the drivability....but go with a descent cam....
Old Feb 25, 2004 | 03:48 PM
WS Sick's Avatar
Am I wrong or couldnt you just plumb the sparkplugwires and injector harnesses to match the firing order?
Old Feb 25, 2004 | 09:28 PM
Hawk350's Avatar
Thats what I thought too but from what I hear the PCM will reconfigure itself and blah blah blah.....I guess this will work on carborated not computerized....dont really sure...
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
