new block
Old Aug 27, 2003 | 03:35 PM
jonaddis84's Avatar
new block
Does anyone know the part # for a new from GM lt1 block. I blew mine up, put a hole in the #5 cylinder wall, oil pan, and broke a rod, lifters, cam, everything. I am leaning towards buying a new block since ebay blocks scare me. I plan on buying a new one and just building a 381, leave the block alone, just get it honed, and put a 383 rotating assembly in, forged everything. So basically im asking if this is the best idea and for the part# and the price? thanks
Old Aug 27, 2003 | 03:47 PM
EviLZ28's Avatar
I checked my books and also have asked GM about this before. They do not list a part number for just a block. They only sell short blocks for the LT1. Or should I say the least amount of engine you can get is a short block.
Old Aug 27, 2003 | 03:51 PM
jonaddis84's Avatar
That is retarded, anybody else find a loophole or anything?
Old Aug 27, 2003 | 03:53 PM
TreySpeed's Avatar
On permanent vacation
just buy a used block machine it and call it good. its just as good as a new one. an Lt1 block should cost you $300 at MOST- id say $200.
Casting number for LT1 block is 327, no relation to the 327ci sbc.
Old Aug 27, 2003 | 04:00 PM
jonaddis84's Avatar
The thing is that since I need a new block anyway, if it costs me $500 or $600 from GM id love to save the money on machining a used block, probably another $500 to bore it. It seems way more practical to buy a new block and build a 381, since used blocks can have tiny fractures that machining can not fix, if i get it magnafluxed xrayed and all that bull****, you still cant fix it so im out $200/$300 bucks.
Old Aug 27, 2003 | 04:01 PM
The full casting number for the LT1 block is:
10125327
The same number is used for both the 2-bolt and 4-bolt blocks. As far as I know, GM stopped making LT1 blocks at least 3 years ago. I tried back then for a new 4-bolt block for my stroker and couldn't find one. Every once in a while, a dealer will find a small batch of blocks or engines... about a year ago, Burt Chevrolet in Denver was selling some 4-bolt marine short blocks he has found in a warehouse.
If you are going to build a stroker, just get a used block, get it magnafluxed and thickness checked and then start the machine work.
Old Aug 27, 2003 | 04:06 PM
jonaddis84's Avatar
So injuneer, you think I would be alright buying a block off ebay? It kinda scares me, but I guess I dont really have a choice. What kind of things should I look for? And is there maybe a better more reputable place than EBAY? Also how much am I looking at for machining 20 or 30 over, balancing, and assembly of the shortblock?
Old Aug 27, 2003 | 04:37 PM
TreySpeed's Avatar
www.cmotorsports.com
they might sell a machined block- i know they will sell you a rotating assembly for close to what you will pay for a new block, machine work, parts, balancing, assembly, parts, and all the little headaches. Plus its waranteed
Old Aug 27, 2003 | 05:15 PM
EviLZ28's Avatar
I just rebuilt a shortblock 355. Machine work on block(Hot tank, Line bore and deck check, bore and hone, freeze plugs) I had them polish and balance my crank, rebuild my rods with arp bolts and balance. Install new Forged pistons. I had them assy the shortblock and also got a new oil pump and gaskets for a total of 1900.00
oh yeah. also included in that price was moly rings, racing bearings
Old Aug 27, 2003 | 06:19 PM
JodyJ's Avatar
Jason Short is selling two type of blocks, one 2 bolt and one 4 bolt. Here's the link: http://web.camaross.com/forums/showt...ferrerid=22266
Jody J.
Old Aug 27, 2003 | 07:41 PM
TreySpeed's Avatar
what rods? what timing chain... all that stuff taken into concideration
$3000 for a rotating assembly with NEW forged rods, NEW forged pistons, all new rings, Heavy duty timing chain, balanced, blue printed, ARP stuff and machined isn't too bad.
then again, there is the quality of the work. Pay for what you get.
Old Aug 27, 2003 | 08:01 PM
EviLZ28's Avatar
Dont forget shipping which is alot to ship from Nevada and then the core charge. For the price of that combined. Its probably another 600.00 at least. For 1600.00 difference in price, I am sure he has a good machine shop out his way that still can put together a better bottom end for what it would cost to buy that motor and have it shipped plus pay a core charge.
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
