new best times
Old Nov 10, 2006 | 05:54 PM
red 95 z28 lt1's Avatar
new best times
went to e-town this weekend, impressed with the few things i did
last time i ran a 12.20 @112 it was in the summer and i took out 100 lbs of weight
this time it was 44 degrees out 0 humidity and all i did was add a 58mm throttle body and check over all the nuts and bolts on the suspension,
11.86 @114mph w/ 1.64 60 ft ran that same time twice. (runs were NA too)
let me know what u guys think
Old Nov 10, 2006 | 06:25 PM
MeanGreen97Z's Avatar
What did it do on the dyno?
Old Nov 10, 2006 | 06:54 PM
Also what were the track conditions?
Old Nov 10, 2006 | 07:00 PM
speed_demon24's Avatar
You have an LE2 396 and you're only trapping 114?
Old Nov 10, 2006 | 08:05 PM
kline454's Avatar
trap speeds are low, i bet a dyno tune would help you a lot.
Old Nov 10, 2006 | 11:59 PM
track was good never had a problem with hooking
Old Nov 11, 2006 | 06:01 AM
Shon Herron's Avatar
WOW, another hard charging big cubed package.
Old Nov 19, 2006 | 07:16 PM
marshall93z's Avatar
I believe you need a dyno tune.
Old Nov 19, 2006 | 07:22 PM
What compression is this motor running? You need to get that car figured out. You have some serious issues going on somewhere. Even at Englishtown you should be trapping over 120 with that package. DCR? DA at the track during this time? Elevation? Post up the tracks numbers for that night and a full mod list. We gotta get that thing running.
Old Nov 19, 2006 | 08:08 PM
zx1216's Avatar
yeah, i did 114 on the stock heads in 85* weather, something is up somewhere....Shon Herron you need to grow the *** up and give up the smack talking, thats sad if you honestly don't have anything better to do...
Old Nov 20, 2006 | 08:12 AM
WHAT?!!? For the past 2 weeks I have been giving guys HECK about their cars running 114 (around the same MPH as my Bolt On Car with let's just say 100 less HP to the wheels) and then I give props to what seems to be the norm. I mean, most of the cars on here are in the 114-117 range so I need to change my perspective. And with that change I say 'good job' and get blasted.
What does the community want? Shon to be honest or Shon to change his perspective on things and accept 383s running 114-117, I can do either, just makes no sense.
And I just noticed you are running what would appear a high mileage LT1 with just a 306 cam and running 114, does that not make you go WOW???!!!!????
Old Nov 20, 2006 | 08:50 AM
Z-RATED94's Avatar
Shon, maybe you are a changed person, but I doubt it. And I'm not sure if a new you would be as entertaining as you have been in the past. You have to admit the above qoute seemed like you were bashing another LE car and that's the Shon we know. That and the Shon that can be very helpfull at times. So why not help this guy out and throw a few suggestions his way. Nice car you have by the way, I was checking out your page.
Old Nov 20, 2006 | 08:54 AM
Most of the suggestions I throw out on these types of cars people do not like
Thanks! I hope in '07 we are able to produce some more results
Old Nov 20, 2006 | 10:24 AM
I will have to build an LE2 package then...
Old Nov 20, 2006 | 11:49 AM
Daniel6718's Avatar
so are you hating on h/c/stroker trapping at 114, and cammed cars trapping 114, bc id take it offensively, my junky 306 motor only traps 112...
