New best ET and MPH tonight... N/A LE car.. etc
Old Feb 20, 2008 | 09:35 PM
Javier97Z28's Avatar
Moderator
Best ET: 11.276 @ 119.45
Best MPH: 11.299 @ 119.58
Passes went like this:
1st 11.306 @ 119.45 1.587 (1/8: 7.189 @ 95.50)
2nd 11.373 @ 119.26 1.601 (1/8: 7.241 @ 95.02)
3rd 11.299 @ 119.58 1.577 (1/8: 7.186 @ 95.49)
4th 11.276 @ 119.45 1.588 (1/8: 7.164 @ 95.70)
5th ?? spun, can't find slip, crappy run... still in the 119's.
I should have some video later.
DA was about 600'.. similar to my previous best.
Race weight: 3575 with driver
Got lucky, didn't get booted
Old Feb 20, 2008 | 09:38 PM
speed_demon24's Avatar
Not bad for a little n/a 355, looks like the tb/springs helped a bit. Now get the videos up.
Old Feb 20, 2008 | 09:40 PM
MeanGreen97Z's Avatar
Nice!! 119 is real close.
Old Feb 20, 2008 | 09:41 PM
mdacton's Avatar
Whats in your suspension?
You just need a little more...I think the mph is good, get it to leave a little harder and get that 10.99
BTW what do you mean booted? don't tell me your running without a bar...
SS MPSTR's Avatar
nice times. that car is hauling the mail, for sure.
Old Feb 20, 2008 | 09:44 PM
Moderator
Suspension is bone stock, cept for LCA's.. stock 90k mile shocks/springs, stock TA, no relo brackets.. nada.
Tune and suspension are next on the list of things to do.
Nope, no bar yet. It's hit and miss whether I get booted for no bar. When I put the bar in I'll pull the back seats, seatbelts, etc to compensate some of the weight going in.
Thx man.
Old Feb 20, 2008 | 09:46 PM
mdacton's Avatar
man get some suspension......you have the h.p.
Not sure about the tune, if you think it needs it go for it. Get a bar too
Old Feb 20, 2008 | 09:52 PM
Moderator
Thx dude.. suspension will be the next expense. I'll prolly just dyno the car to check the tune, it might be just fine.
And I'll put a bar in too
Old Feb 20, 2008 | 10:14 PM
slomarao's Avatar
some light weight carpet will help offset the cage too. Do you pull the front sway bar?
I think you a torque arm, airbag, and relocation brackets away from 10's. Shocks and springs will def get you there if done with the parts above.
Nice times, wish mine ran those numbers.
Old Feb 20, 2008 | 10:32 PM
I have a friend with an LG torque arm in his garage he will let go cheap for sure.
Old Feb 20, 2008 | 10:50 PM
Moderator
MeanGreen.. can't hurt to try it for now! Let me know how much he wants.
Old Feb 20, 2008 | 11:00 PM
mad95z's Avatar
Nice times, If you get the suspention dialed in, Im sure you'll dip into the 10's
Old Feb 20, 2008 | 11:04 PM
Jlo's Avatar
Jlo
Great Times.....I smell 10's....as well....Kudos Bro.....
Old Feb 20, 2008 | 11:43 PM
2000GTP's Avatar
Very nice. Must be nice to have that warm weather year round.
Old Feb 20, 2008 | 11:50 PM
mad95z's Avatar
I agree, Its -10 below zero here. Thank goodness for the heated garage, and the heads/cam combo in the works. keeping the warm weather dreams alive.
