new 383 not starting
Old Jan 16, 2008 | 10:36 PM
thebufenator's Avatar
the details of my build are in my sig.
I know I have fuel, as I had a fuel leak I just fixed, the fpr was leaking.
I just installed the engine these last few days. When I try and start it it sounds like the battery is dead........really laberous cranking. I hooked up a second battery, and it tried harder, but still had a hard time. It never fired up either.
Is it possible the stock lt1 starter cant handle the higher compression 383?
I have yet to check for spark.....
Old Jan 17, 2008 | 07:34 AM
Is is possible the leaking FPR partially filled the cylinders with fuel?
Old Jan 17, 2008 | 08:36 AM
rich152's Avatar
Yes a factory starter can handle the 383. The battery may be putting out low current. Post up after you check for spark.
Old Jan 17, 2008 | 09:29 AM
When I get back to the car tonight I am gonna see how hard it is to turn the engine over by hand, I know it was very smooth turning over before being bolted into the car.
Depending on how that goes I'll start pulling plugs to check the cylinders.
Also gonna check the thick ground wire by the starter and make sure its grounded well against the block.
Question, if my battery gauge shows 12volts with the water pump running, the battery should be good right?
Old Jan 17, 2008 | 03:44 PM
Not necessarily. It only takes a few amps to feed the water pump. The starter takes hundreds of amps.
Old Jan 17, 2008 | 09:33 PM
well here is what I did:
1: the ground near the starter with wasn't connected.
I attached that to the block.
tried to start it again, still didn't do it.
2: connected a second battery. Before attempting to start with both I stuck a wrench on the balancer and turned the engine over. While hard to crank, it still turned over smoothly, proving that there wasn't fuel in the cylinders hydrolocking it.
attampted to start it again, no go, but it tries harder.
before giving up I took off the accessory belt and tried one last time.
SHAZAAM! it started, although barely.....it turned over so slowely that I didn't think it could, but it did
So now I am going to be recharging my battery........and figure out why it cant start.
How do I check for the voltage drop?
Old Jan 23, 2008 | 09:09 PM
The car is starting just fine, but it wont idle.
I have to give it gas to keep it from dying. It sounds like it wants to idle around 950RPM.......any lower and it sounds ready to stall.
Also, it smells really rich on startup.....
I cant get my datalogue cable to connect using my laptop either.
Old Jan 23, 2008 | 09:20 PM
94zgreenmachine's Avatar
I had the same problem with mine at start up. I had to open the blades a bit and slot my tps to adjust for the blades being cracked open. I am going to drill out the hole in the tb so it will idle, not sure how much so I'll take it slow.
cheapchevy
Apr 8, 2015 08:48 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
