New 355 Problems!
Old Jun 25, 2004 | 07:58 PM
Fastbird93's Avatar
Angry New 355 Problems!
Man, I swear it's always something with my black car.
Went down to FBC today to fire off the new motor. Get it all primed and everything, ready to go. Crank, and that's it. No spark. Trace it down to a blown Ignition fuse, we got spark!!! Fire it up, and all ya get is THUD THUD THUD THUD. WTF right?? We put the car on the lift, and the freaking Rods/Rod Bolts are making contact with the stock oil pan.
I don't get it. It's only a 355. Stroke is still a 3.48, rods are 5.7 H-Beam.
Anyone else have this problem when moving to aftermarket equipment?? Car is staying on the lift and the shop is just going to bang out the oil pan some, but dang, I didn't expect this.
Old Jun 25, 2004 | 09:00 PM
n2ceptor's Avatar
Did you happen to notice if the rod caps were taller than stock???
That might be it.....
Old Jun 25, 2004 | 09:05 PM
Fastbird93's Avatar
That's what we're thinking. I don't think it's going to come to a new pan, but this has just been one thing after another at this point.
I just haven't heard of anyone having an issue like this with a 355.
Old Jun 26, 2004 | 07:45 AM
IllusionalTA's Avatar
SOunds like normal growing pains!.. Did you do a k member as well? If not i guess the motor has to come out .. Did you guys rotate the motor making sure everything is kosher? i'm sure you would have found this if that was done! YOu could always leave it and it'll bang itself out.. or airate the pan.. Find a cheap canton/stef's pan and call it a day..
Old Jun 26, 2004 | 11:42 AM
Fastbird93's Avatar
No K-Member, but the car is staying on the lift, so works in progress. The shop that buttoned the motor up didn't notice anything in the process. Granted, I've never head of a clearance problem like this on a 355 in the first place. It's not like I'm using any outlandish parts or anything either. Another oil pan is out of the question. I'm tapped out on funds at this point.
LeftoverChinese
Jan 14, 2024 03:03 PM
drptop70ss
Mar 26, 2015 01:50 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
InfernalVortex
Jan 17, 2015 09:35 AM
T/A lt1
Oct 10, 2002 03:14 PM
