Never Seize, or thread sealant...
Old Nov 16, 2007 | 04:46 PM
marshall93z's Avatar
For rocker arm studs that DO NOT protrude into the intake port?
Old Nov 16, 2007 | 05:24 PM
Kevin Blown 95 TA's Avatar
You mean blind holes? Use neither, but never-seez, although it wouldn't hurt anything, would alter your torque spec.
Old Nov 16, 2007 | 05:51 PM
I have no clue what a "blind hole" is?
Old Nov 16, 2007 | 06:14 PM
97s10ondubs's Avatar
It means the hole just bottoms out, doesnt hit water or anything else that the threads would need to be sealed from.
Old Nov 16, 2007 | 06:20 PM
Gotcha!
Two holes DO have oil in them though. Just a little bit. But I didn't see a hole in it anywhere.
Old Nov 16, 2007 | 08:25 PM
FASTFATBOY's Avatar
What do you guys put on rocker studs that DO protrude into the intake port? Liquid teflon sealer?
David
Old Nov 16, 2007 | 11:58 PM
kylersaulsbury's Avatar
David: Permatex Thread Sealant.
Marshall:The oil that is down in the bottom of the hole seeped in there through the threads of the stud. If your worried about it then use the sealant but you will be fine.
Old Nov 17, 2007 | 12:28 AM
Okay, thanks!
Old Nov 17, 2007 | 03:33 PM
David
I used the ARP sealant that I used for the head bolts.
n2oblkz
Oct 22, 2015 02:31 PM
Double aught
Oct 2, 2015 11:29 PM
Formula Steve
Sep 19, 2015 08:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
cmsmith
Aug 17, 2015 06:50 PM
