Need wiring help on CSI pump...
Old Nov 11, 2003 | 05:10 AM
96 WS6's Avatar
1) When you connect the LED does it matter which lead you hook as power or ground? I just hooked it up and I can't remember which way I did it but i figured it did not matter.
2) What fuse can I tap for power to activate the relay? I already have my tach activated by the ten amp fuse. Can I use any of the other fuses to get power?
Old Nov 11, 2003 | 01:14 PM
llafro's Avatar
I think it does matter. I tried mine one way and it didn't work. The other way it did light up.
I used the "Cruise/AC" fuse, but you can also use the "IGN" fuse under the hood in the box on the driver's side. The draw to power a relay is really small, so it's not a problem to add it on to an existing circuit.
HarleyZ28
Oct 5, 2015 06:23 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
lbrowne
Nov 13, 2011 04:25 PM
97FormulaWS-6
Sep 11, 2002 11:57 AM
turbo_Z
Aug 19, 2002 10:50 PM
