need tons of help
Old Jun 1, 2005 | 10:38 PM
ericz28w's Avatar
need tons of help
ok i can sleep over this stupid problem, well its kinda hard to explain, but ill give it hell. i have a erradic problem of blowing the ignition fuse in the engine compartment (10 Amp). it happens sometimes, not every time so it is very hard to diagnose. but when i get on it hard, mostly in first, second and sometimes in 3rd, the ignition fuse blows instantly and my car shuts off. you can ease into the throttle all the way up the rpms with no problems (so far). i have checked all the wires that i think could be a problem and they appear to be ok. i have a new opti, stock coil, new wires, obd1 conversion. this has been going on for 2 weeks, and i think i fix it, then it pops that fuse again.
i cant figure it out and im not very good with electrical problems so if u guys could give me any help i would greatly appriciate it.
and if i need to give any more info on my problem let me know.
Old Jun 1, 2005 | 11:12 PM
bdc95ta's Avatar
Re: need tons of help
does the msd 6a require you to run a greater amp fuse?
Old Jun 2, 2005 | 06:14 PM
ericz28w's Avatar
i do not have the msd hooked up right now, do u think the new motor would need a higher amp fuse??
Old Jun 2, 2005 | 06:47 PM
1racerdude's Avatar
Put a 20 in it.It's small enough to blow if there is a problem and should be large enough to carry the load.
RUENUF
Mar 13, 2016 03:37 PM
Hal Fisher
Sep 30, 2015 09:03 PM
WPHIG2
Aug 27, 2015 06:37 AM
Rittmeister
Aug 12, 2015 03:50 AM
Devinfoote87
Jul 30, 2015 09:54 AM
