Need Timing Chain ASAP - Recomened Chain When I Have Electric H20 Pump.
Old Jul 10, 2008 | 04:22 PM
ENRKyle20's Avatar
I put off gettin a timing chain until now. Now that I need it I need to make a decision. I went ahead and bought a electric waterpump.. SO, now I need to know what chain to order. I would like it to be direct bolt in, I dont want to modify the cover at all.
Recomendations?
I am using comp beehive springs, .600 total lift, Le2 cam.
Old Jul 10, 2008 | 04:44 PM
jclark311's Avatar
I used this one from Summit, its good quality, and if you want to go back to the stock water pump you wont have to change it.
Timing set Cloyes CLO-C-3039 78.39 Summit
Old Jul 10, 2008 | 05:28 PM
ENRKyle20's Avatar
wait. I can run that with a waterpump?.. I didnt think there was any strong chains besides that LT4 ED timing chain that will work and still run the waterpump.
I will cancel my order for my waterpump and just buy that.. Is this new?. I always heard people saying that cloyes will require a electric waterpump..
thanks
Old Jul 10, 2008 | 06:15 PM
black/blue's Avatar
I was curious if a gear drive setup would fit under the cover?
Old Jul 10, 2008 | 06:31 PM
You're kind of hijacking the thread, but gear drives are noisy and cause knock sensor issues.
Old Jul 10, 2008 | 06:40 PM
ShownomercyZ28's Avatar
Pro gear single roller
Old Jul 10, 2008 | 06:41 PM
ENRKyle20's Avatar
I dont mind. I had G2G timing in my 82 camaro and I fell in love with the sound. I would LOVE to run a noisy gear drive, but I value my knock sensors.
They make quiet and noisy gear drive timing systems, it all depends if its a straight or angle cut on the gears.
Old Jul 10, 2008 | 10:25 PM
black/blue's Avatar
It was more of a general question, if it would fit you could run just about any timing chain set correct.
Old Jul 11, 2008 | 08:17 AM
seawolf06's Avatar
That is the stock style chain with the waterpump drive. You should be able to use it with the stock waterpump.
I didn't know Cloyes made one for our cars, good to know!
Old Jul 11, 2008 | 10:04 AM
96lt4vette's Avatar
I used a Cloyes 3145 on mine. It did require a tiny bit of clearancing on the timing cover, but otherwise works great (no wp drive)
Old Jul 11, 2008 | 01:17 PM
1963SS's Avatar
I used a Cloyes 3157 on mine. Big ole' rollers and no clearance issues at all. Almost no chain slop like the stock butt link chain.
Old Jul 11, 2008 | 05:07 PM
bowtiedad_z28's Avatar
Will any of these work on a 94 with ewp?
Old Jul 11, 2008 | 06:50 PM
seawolf06's Avatar
They all will.
Old Jul 11, 2008 | 07:41 PM
CGrant's Avatar
I have a sbc double roller on mine that fit perfect, i installed it in 2003 and dont remember what brand, looking for it now.
I did require me to run an elecric pump.
Sergio
Jan 27, 2016 04:27 PM
nikolt1
Feb 27, 2015 09:10 PM
BMX Dad
Jan 23, 2015 07:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
