Need suggestions on rotating assembly
Old Oct 11, 2005 | 10:33 PM
1QuikTransAm's Avatar
I plan on building a 383 over the winter. I've already got the block with all machine work done, now i'm just trying to decide on what rotating assembly to go with. My current plan is to run a LE3 h/c set up with about 11.0:1 or so cr and possibly a 150 shot later on down the road. Would an eagle forged crank, 6.0 h-beam rod, and je srp flat top piston set up be able to handle all of that pretty easily? Or is there a need to get stronger parts?
Any input would be greatly appreciated!
Adam
Old Oct 11, 2005 | 10:37 PM
amean94ta's Avatar
Re: Need suggestions on rotating assembly
Eagle will be perfect just make sure you buy it unbalenced and have them shave the weight off the flywheel and balence it at a shop
Old Oct 11, 2005 | 11:49 PM
Thanks!
Does anyone know about how much hp the Eagle forged 4340 crank (3.75 stroke) is rated at?
Old Oct 12, 2005 | 07:13 AM
FastZinTennessee's Avatar
I've heard from a couple of people, one being my machine shop, and another person is on this board that the eagle 4340 crank and H-beams will support a little over 1,000 fwhp. I don't think you have anything to worry about
Old Oct 12, 2005 | 03:49 PM
Well that's definitely good to know. Looks like i'll be going with the eagle forged rotating assembly...
Thanks!
KYWes
Jun 14, 2022 06:52 AM
surreybrad
Jul 5, 2015 10:36 PM
Campbellb48
Jul 5, 2015 06:31 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
