Need suggestions on Header Gaskets and Bolts...
Old Feb 13, 2005 | 06:53 PM
lamb110's Avatar
which type fo gasket should i get round port style or square port style, i'm looking at Percy's header gaskets and didnt know which type to get, prolly a stupid question but then again i'm not that bright
also whats the best type of header bolts to use, i dont want to use locking just a good set of regular header bolts, both of these would be used on a set of Jet Hot LT's.
Old Feb 13, 2005 | 06:56 PM
wicked_95z's Avatar
Re: Need suggestions on Header Gaskets and Bolts...
fel-1406 and breslin lockers
Old Feb 13, 2005 | 07:03 PM
lamb110's Avatar
I'm hopefully buying the headers and y-pipe from a guy here in the forsale section, he had them on a 95 Z28 will the headers and y-pipe fit on my 97 Z28?
they are Jet hot LT's and a Mufflex Y-pipe.
Old Feb 13, 2005 | 07:27 PM
hellostop's Avatar
New factory steel gaskets will last a loonnggg time.
High quality bolts that can be turned with a wrench or allen drive can be a big time saver.
Old Feb 13, 2005 | 09:15 PM
redcamaroz28's Avatar
I vote factory ones. I put them on w/ my mac headers and when I took them off a year and a half later (head gasket blew), they didn't have a single leak upon visual inspection of the gaskets.
Old Feb 13, 2005 | 09:54 PM
DonHood's Avatar
I also used the factory steel gaskets, worked out great for me.
Old Feb 13, 2005 | 10:14 PM
CreatiVe2's Avatar
i have heard a lot of good feedback from the felpro's i just got these for my header install (pending)..
Old Feb 13, 2005 | 10:17 PM
Bud M's Avatar
Earl's gaskets have worked well for me.
Old Feb 13, 2005 | 10:27 PM
turbo_Z's Avatar
I have tried the 1406 and they leaked. Also used the percys and they leaked. So far the only gaskets that have worked are they stock replacements.
Old Feb 13, 2005 | 11:03 PM
RCF925's Avatar
I've used Mr. Gasket for quite a while now on a several different kinds of headers with no leaks.
Old Feb 13, 2005 | 11:42 PM
RedRyder518's Avatar
Would the stock replacements work well for AS&M headers? I once had a loose bolt on my manifolds, and I mean a really loose bolt which allowed for a hella exhaust leak. Anyhow, I let it do that for a while (BAD MISTAKE) and it never even ruined the gasket! They seem to be pretty badass if they would work for aftermarket headers?
Old Feb 13, 2005 | 11:55 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I had the worst luck recently w/ my pacesetter install... The Earl's gaskets worked great. Whereas the other ones.. Felpro's, Mr Gaskets, and stock replacement all leaked. First time I've ever had this many problems though. I used to use felpro 1406's w/out issue on my hooker lt's.
Old Feb 14, 2005 | 12:34 AM
Zack's Avatar
i went with felpro's and ARP bolts for my edelbrock headers
Sauced
Apr 12, 2015 10:18 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
thenewkid
Nov 27, 2014 09:41 AM
