need for speed..topping out at 120 mph
Old Feb 6, 2004 | 09:44 AM
metallicamaro's Avatar
hey i was just wondering if there is some kind of governor i can manipulate to get past 120 mph. It just seems to top out once it hits 120.
Old Feb 6, 2004 | 09:48 AM
ppmz28's Avatar
Some camaros do come with a gover.(I've heard) Mine doesn't though. I know you can get gover. took out
Old Feb 6, 2004 | 09:58 AM
Fastbird93's Avatar
Does it feel like you're hitting a limiter at 120, or does the car just quit pulling?? If it hit's a limiter, then a hypertech or a tune could take care of the limiter. If it just quits pulling, you may have deeper issues.
Old Feb 6, 2004 | 10:48 AM
S.J.S.'s Avatar
You would tell if it was hitting a limiter. Well you should know. How does it act at 120??? I notice your new to the board. WELCOME! You will learn a lot here and learn to live by this board as I and many others have. I didn't know squat about my car. The next hing you know I built my own engine without this board I doubt I would or could have ever done it. Anyway you need to put up a signature (note on the bottom of your car) so we know what year and model you have.
Old Feb 6, 2004 | 10:51 AM
SVT Killer LV's Avatar
LT1's had the option of having Z rated tires come stock or not. If that option was not checked they weren't shipped with Z rated tires and come with a 120mph "governator", Any performance tune or programmer will get rid of it
Old Feb 6, 2004 | 11:03 AM
MY91Y84's Avatar
Just like the 3rd gens...without z rated tires 110 was the limiter i think..mine did 145
Old Feb 6, 2004 | 11:28 AM
Terran2k's Avatar
if you have an auto and are at 100% throttle at 120, i dont believe a 4L60E tranny will go past it. u have to be some where around 70% i think, but i could be wrong.
Old Feb 6, 2004 | 11:45 AM
thanx for all the helpful comments. Ill try to get some pics up once it gets out of the shop. then i can start on my performance!!!
Old Feb 6, 2004 | 11:53 AM
Coolformula's Avatar
If your car has a 155 speedo it should have come from the factory with z rated tires and be able to do 155+.
If not you have the 110 speedo you need a tune or hypertech to remove it.
Only the older 700r trannies wouldnt shift into 4th( over drive) at 100% you had to let off.
You got the 460le and it will shift into 4th at wot(wide open throttle). trust me i got one
Old Feb 6, 2004 | 12:31 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
i might be off here but i thought the z28 option meant z rated tires, a 155 speedo, and an lt1. you guys have me second guessing.
david
Old Feb 6, 2004 | 12:37 PM
LT4Firehawk's Avatar
The Z28 option doesn't have anything to do with z rated tires. The Z28 model is the V8 version of the Camaro (at least in the 4th gens).
95chwagon
Oct 16, 2015 12:24 PM
4586
Sep 27, 2015 01:55 PM
95blkss
Sep 22, 2015 03:18 PM
NewsBot
Sep 14, 2015 09:20 AM
mmf_1013
Sep 12, 2015 08:56 PM
