Need some major cam help guys...
Old Oct 6, 2003 | 09:57 AM
rocmemphis's Avatar
Question Need some major cam help guys...
I got my camshaft installed this weekend but when I go to put my opti back on the dowel pin is just slightly short and the opti will install flush no matter how I put it on. Short of having to pull the cam back out is there anyway I can get the pin out?
P.S. Dont work on your car when you are tired
Old Oct 6, 2003 | 10:07 AM
joeSS97's Avatar
You want it to sit flush.As long as the pin goes in the hole in the opti far enough to turn it and not slip out,
Old Oct 6, 2003 | 10:36 AM
rocmemphis's Avatar
Well the pin on my stock LT1 cam went in the hole and I could tell if it was not in. The pin on the hotcam I question if it is going in or not b/c I can install the opti with the pin hole opposite of the dowel pin.
Hopefully I am making sense with my explanation.
dfarr67
Apr 10, 2015 07:44 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jazsun
Dec 29, 2014 12:14 PM
