Need some info on Optispark
Old Oct 29, 2004 | 07:20 PM
NuMbNuTs670's Avatar
Does a brand new optispark come with that plastic cover and anything I should know about while doing the swap?
Old Oct 29, 2004 | 07:32 PM
hotrod18_69's Avatar
Re: Need some info on Optispark
It should be a direct replacement, pull yours off and put the new one on. It really easy.
Brad
Old Oct 29, 2004 | 07:48 PM
Kataklysm's Avatar
Make sure you get the right one for your car. 93-94 were NON VENTED while 95-97 were VENTED. They are set up different and are not direct replacements, if you have a non vented you can switch to a vented with a few extra parts.
Old Oct 29, 2004 | 08:24 PM
... My new opti doesn't have the plastic cover
Old Oct 29, 2004 | 08:35 PM
Josh-'04 GTO's Avatar
Huh? Do you mean the actual casing itself? Is this an OEM replacement, or an Autozone/NAPA/Advance POS?
Old Oct 30, 2004 | 12:32 AM
indieaz's Avatar
If your new opti doesn't have the plastic cover you probably got an autozone opti, which is not the complete unit. Most are gunna suggest getting the complete unit from GM etc. You CAN use that opti, however you're gunna have to dissasemble your existing one to put the new cap & rotor you got on it. It's not too difficult to do but it's probably a good idea ot just get a new one.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
CARiD
Sep 7, 2015 08:21 AM
