need some help tracking down a problem
Old Apr 25, 2003 | 11:56 PM
PaulN64's Avatar
this is a tranny problem. So here's what happens. Sometimes, at low or high rpm, the tranny won't shift into gear. This is mostly on 2nd and 3rd. I would have to go back to neutral and then try go back into gear. Also, mostly 1st through 4th grear, sometimes it'll grind going in. At high rpm, the shifter will throw out of gear 3rd and 4th gear when shifter after I release the clutch. So any clues/suggestion? or is the tranny about to go bye bye?? any help would great.
Old Apr 26, 2003 | 12:03 AM
johnpsz's Avatar
I had a similar situation a while back with a mustang I had, my problem was the synchronizers were shot.
I got a couple of questions for you, How many miles on the tranny, and how long have you had the shifter on the car?
I hope this is a help to ya.
Old Apr 26, 2003 | 12:09 AM
PaulN64's Avatar
I've had the car brand new since Nov 96. I've got 88k on my car but it's been doing this for a while now. The Pro 5 shifter was put on a few months ago, not sure when but it was kind doing this before the Pro5.
Old Apr 26, 2003 | 12:29 AM
camaronutt's Avatar
My thoughts would be, either your syncros are out or your shifter stops aren't letting the tranny in gear the wole way.
__________________________________________
96 Z28 M6
All stock, under drive on the way.
14.02@ 99.77 best time.
Old Apr 26, 2003 | 12:33 AM
PaulN64's Avatar
96 Z28 M6
nope, I'm not using the stops at all. I thought that might be the reason when it did that the first time so I put the stops all the way out.
Old Apr 27, 2003 | 12:50 AM
PaulN64's Avatar
any other ideas?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
