Need some help with setting spring heights (847)
Old Oct 21, 2003 | 11:07 AM
madwolf's Avatar
Arrow Need some help with setting spring heights (847)
I'm getting ready to install an 847 cam in a 94 engine and need some help with the spring height.
I have:
gm 847 cam
cm's 612 springs.
pro magnum 1.6 non self aligning RRs
comp r lifters
comp hi tech 1 piece 7.2 pushrods
gm guideplates
the heads are stock and will stay on the engine.
What are the steps I should go through to find and set the correct height? (for this setup I mean)
Also, where can I buy shims?
Thanks!
grabbem88
Feb 22, 2015 11:16 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
