need some help, running rich
Old Jun 29, 2004 | 11:51 AM
tagz's Avatar
I may have posted this on here before. but i'm still stumped. My car is running RICH!!! I changed the plugs, wires, o2's, pcv valve, fuel filter, and i did a fuel pressure test (good) and a vacuum test (perfect).
What else can be causing me to run rich? I have ran fuel injector cleaner through it, but that did not help. What else can it be? Once my laptop charges, i'll post a data master log for you guys to take a look at.
Old Jun 29, 2004 | 12:30 PM
valter's Avatar
It can be a lot of things. Check for exhaust leaks, check and clean your MAF, IAT, EGR. May be your PCM is reprogrammed or smth? If not exessive, running a little rich alot better then lean for a motor...
Old Jun 29, 2004 | 12:33 PM
tagz's Avatar
EGR is removed and blocked off. MAF is descreened, but i'm not the only one running a descreened MAF. it did it before and after my long tube header install, so i'm assuming it is not an exhaust leak.
I'l get you exact number in alittle bit.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
