Need some help from a 97 Camaro owner.
Old Nov 12, 2004 | 08:46 PM
madwolf's Avatar
I was wondering if someone would be willing to help me with some measurements.
I need 5 measurements of the 97 Camaro instrument cluster bezel.
Here's a lousy picture of the measurements I need.
They do not need to be 100% accurate, but as close as you can get them is fine.
Thanks a lot!
Old Nov 12, 2004 | 10:21 PM
My Iroc Z28's Avatar
Re: Need some help from a 97 Camaro owner.
Thanks a lot!
Do you still need these #'s
Old Nov 12, 2004 | 10:36 PM
madwolf's Avatar
Yep, I just posted that a couple of hours ago.
Old Nov 13, 2004 | 04:38 PM
ShelbyZ28's Avatar
If no one posts any measurements by tomorrow afternoon I can take some. I have to take that off anyway to swap out a couple of my LED's.
Bryan
Old Nov 13, 2004 | 04:44 PM
madwolf's Avatar
Thanks Bryan!
If you're taking the cluster out, please take the same measurements of the cluster too. Thanks again!!!
Old Nov 15, 2004 | 07:10 AM
ShelbyZ28's Avatar
Sorry Ion I didn't get a chance to do that yesterday. I thought I would get off work at 12 but ended up working until 6. I can still get the measurements this week sometime but I'm not sure when.
Bryan
Old Nov 15, 2004 | 09:35 AM
1stz28's Avatar
These aren't the most accurate...weren't done with a caliper or anything like that but since nobody else has put up anything I thought I would take a stroll outside and measure away.
1. overall width 18"
2. width of inside opening 14"
3. overall height 9"
4. height of opening (center) 3.5"
5. height of opening (left of column ) 5.25"
Hope it helps.
Old Nov 15, 2004 | 02:14 PM
madwolf's Avatar
Hope it helps.
Thanks a lot!
Bryan,
if you ever take that cluster out and could measure it, that would be great! I am in no rush with this so whenever is fine.
Thanks again guys!
Old Nov 15, 2004 | 02:36 PM
1stz28's Avatar
Anytime...I hope to be using your services in the near future. I hear nothing but good things about you from people on this board so I will definitely contact you when the time comes.
Old Nov 15, 2004 | 02:38 PM
madwolf's Avatar
Sounds good!
Remind me to take $20 off your order when you do.
Thanks again,
Ion
Old Nov 15, 2004 | 05:52 PM
ShelbyZ28's Avatar
Thanks a lot!
Bryan,
Thanks again guys!
I'll be sure to do that for you. I'm planning on doing it by this weekend if not sooner. I'll post when I get it done.
Bryan
Old Nov 15, 2004 | 05:57 PM
LT4383's Avatar
Designing a new gauge cluster?
Old Nov 21, 2004 | 04:08 PM
ShelbyZ28's Avatar
Got it measured today...
Total Width: 15 5/8 inches
Total Heigth: 7 inches
Heigth Center: 4 3/8 inches
Width of Arch: 4 3/8 inches
Hope this helps. Let me know if you need some other measurements. Its pretty easy to pull apart.
Bryan
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
