Need Serious Help!
Old Oct 15, 2011 | 07:10 PM
ShowOff67's Avatar
Need Serious Help!
so i just got done the head gasket replacement. i did everything in order and followed every direction on this link http://www.afrashteh.com/guide/install.htm , so when i went to fire the car up it the starter just fires and it sounds like motor is trying to run and it kills my battery if i do this for too long its like its trying to start but cant when i let off the key it just goes makes some exshaut sounds and dies. here i made a video, please help
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=1895& transactionid=1318723803-7610681197&posted_by=ShowOff67_www.camaroz28.com&y outube_video_id=riYm8yQprUg[/autostream]
Old Oct 15, 2011 | 08:27 PM
ShowOff67's Avatar
Re: Need Serious Help!
this car is my daily driver start school in a week need to get things straight help will come with many thanks lol!!!
Old Oct 15, 2011 | 09:34 PM
lt11997's Avatar
start with the basics and make sure you have fuel and spark.
Old Oct 16, 2011 | 07:10 AM
Guest47904's Avatar
Guest
While you're checking for spark and fuel pressure, check the injector clips are on the correct injector.
Check the plug wires are on the right plug.
Plug wire routing
While what you have above is the correct firing order. This
POS is worthless.
And add the information about your vehicle in your signature so if and when it's needed, someone doesn't have to ask. We know it's a 94 but several posts from now, they won't.
Old Oct 16, 2011 | 11:39 AM
ShowOff67's Avatar
the car is a 95 Z28 M6 is there a diagram which injector clips go to what injector? i also just got new wires there summit racing they were loner then the stock wire but i think i put them on correctly, dont have a fuel pressure gague but will be test spark today. i think i didnt put the opti on right would this cause the car to not start?
Old Oct 16, 2011 | 11:59 AM
JGuy07's Avatar
Depending on how far off you are on the opti, it could.
Old Oct 16, 2011 | 12:12 PM
ShowOff67's Avatar
well when i put it in i just put it the way it went... i didnt think it went any other way i was spinning it also before i put it in cause i was comparing how stiff it was to my old one. think this could be the problem? i also upgraded to a msd street fire coil. i put everything back right. so should i take it off and try and put it on different? then when doing this put it back to TDC #1 before i fire it because i know from trying to crank it. it is not in TDC 1 anymore.
Old Oct 16, 2011 | 01:17 PM
ShowOff67's Avatar
so me and my bro where just looking at it had to wench it with the jeep to get it on ramps tryed to start it ones it sounded like it crank but only my cylinder was running like rumble rumble rumble then it stalled
any ideas?
Old Oct 16, 2011 | 01:33 PM
JGuy07's Avatar
The opti is only suppose to go on one way, yet some people manage to put it on wrong without noticing...it happens. keyed grooves are suppose to line up.
Old Oct 16, 2011 | 02:35 PM
bw_hunter's Avatar
POS is worthless.
LOL....it might be worthless but it's exactly what's in the GM service manual.
Old Oct 16, 2011 | 03:27 PM
ShowOff67's Avatar
got the opti off and placed it back on the dowl pin couldnt tell if it was on wrong but it popped back on after putting it on. i dont think it did that last time.
Old Oct 16, 2011 | 10:52 PM
He has a 95.... no splined shaft. Driven by the cam dowel pin.
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
form94
Sep 23, 2015 07:30 AM
rvonsternberg
Sep 14, 2015 11:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
