Need recommendations for a new ignition coil!
Old Oct 18, 2004 | 09:08 AM
izzyz28's Avatar
My car has had a high-RPM miss for the past few months that I thought was the original OPTI. While I was installing my Mallory 685 I pulled the coil wire off the coil and noticed it was corroded and the tower on the coil was extremely pitted. I cleaned it off for now which fixed the problem. The car will pull to 6500 RPM without a stuble. However, I want to get a new coil because this problem will eventually come back. I have heard bad stories about the MSD coil. Are there any other brands I should consider, or should I just get a stock coil from the dealer. If anyone has personal experience with aftermarket coils then I want to hear what you have to say. Thanks in advance.
Old Oct 18, 2004 | 09:19 AM
30696bird's Avatar
Re: Need recommendations for a new ignition coil!
I have a MSD coil, it works fine. If I had it to do over again I would have just bought an OE (stock) coil. JMO
Old Oct 18, 2004 | 09:36 AM
BlownF1's Avatar
I and several other locals run the Crane PS-91 and it works well...no complaints here.
markzzzz
Aug 17, 2015 11:08 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Cam28_boy
Aug 6, 2002 08:40 AM
AdamB
Nov 10, 2001 01:12 AM
