need recommendations
Old Nov 21, 2010 | 10:03 PM
CamDriver's Avatar
hey guys/gals I am new here and to the Lt1 world I been building SBC's since i was 15...I just bought a unmolested 1995 Z28 lt1 6 speed and as most know your better off asking people thats been building them. it is 100% stock I just bought a k&n cold air kit.
I dont wany to go to over bored buy I do want to put a cam, exhaust, ect it is going to be a daily car so if you can give me some ideas thanks!!
Old Nov 22, 2010 | 05:49 AM
SCNGENNFTHGEN's Avatar
Re: need recommendations
Nice choice! Before I spun a rod bearing, mine was an animal for being a stock long block. I have Edelbrock headers, w/ SLP loudmouth exhaust, a K&N cold air kit, a 52 mm throttle body. LT4 knock module, a B&M ripper shifter. That aught to be a good start. What state are you in? I'd like to have some long tubes myself and a stroker bottom end.
Old Nov 22, 2010 | 12:03 PM
97Z28Muscle's Avatar
I just rebuilt my 97 myself. Took about a month or so after all of the machine work and ordering parts. I put a comp cams 503 camshaft in mine with magnum roller rockers. I also had the cylinders honed and the crank polished. I used stick pistons and rods with new rings bearings and gaskets. Clouds timing set and long tubes by pacesetter. Had the ecu tuned by Keith at pcmforless.com. made my own catted y pipe that works perfectly. I put in a new water pump and options also. This car is one fast ride. Nice choice. You are seeing less end less f bodies out there. Its nice to see guys resurrecting. These fine GM automobiles. Good luck with your build.
Old Nov 22, 2010 | 01:53 PM
henryz28's Avatar
One trick to get more out of a smaller cam like the hotcam would be Scorpion 1026 1.7rr's; be sure to run the correct springs, lt4 springs are not good for this set up.
Old Nov 22, 2010 | 08:35 PM
CamDriver's Avatar
thanks! im in florida Ocala area
Old Nov 22, 2010 | 09:35 PM
fastcam91's Avatar
Ocala area huh! Im originally from Inverness right outside ocala. Im in the service now and stationed in cali.
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
Schul365
Aug 25, 2015 05:47 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
jl1ne
Jul 7, 2015 08:38 PM
