Need quick help with location of part.
Old Sep 7, 2004 | 10:24 PM
Silvershark's Avatar
I am in the process of removing my engine/trans. I have all the engine stuff taken care of and I am in the process of removing the transmission. It says to mark the rear axle pinion flange and the driveshaft in order to indicate their relationship. Where is the rear axle pinion flange? I have tried the search and I was unable to come up with anything. Perhaps shoebox can help me here. I know its something simple.
Also, I removed the clutch actuator cylinder and I did not remove the master clutch cylinder pushrod before. I assume as long as I do not push on the clutch it will not ruin the master/slave cylinders.
Do I just jiggle the clutch fork or does it actually pull down like a lever?
I am planning on removing the engine/trans as a whole.
Thanks!
Old Sep 7, 2004 | 10:30 PM
zx1216's Avatar
Re: Need quick help with location of part.
the clutch fork should just "pop" out, just pull on it toward the tunnel. You may have to work it a little bit but it will pull out.
Old Sep 7, 2004 | 10:48 PM
Thanks. How about the location of the Rear Axle pinion?
Old Sep 7, 2004 | 10:56 PM
zx1216's Avatar
i'm not sure what they are talking about? Maybe the u-joint between the driveshaft and the rearend? When i pulled my trany for my clutch job i left the driveshaft on the trany so i didn't have to drain it, i just unbolted it from the rearend at the u-joint.
Old Sep 7, 2004 | 11:28 PM
What they are talking about is the flange on the rear end that your driveshaft is bolted to. That flange is bolted to the pinion shaft of the rear gears, so it is the pinion flange. Make a mark on the driveshaft and continue onto the flange, so that it can be reassembled like it came out. It can only go on one way or 180° opposite that.
Old Sep 7, 2004 | 11:36 PM
Thanks. I knew you would come through! I will go back down and complete the removal.
Thanks again!
Relaquary
Jul 6, 2015 09:42 AM
Scorch1
Jun 30, 2015 11:24 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
