Need a quick answer on timing setup...
Old Jul 13, 2004 | 07:28 AM
texasTA's Avatar
I am trying to decide how I want to go with a timing setup on my 1994 Trans Am a4.
I will be running
Combination motorsports 233/239 111lsa, Comp Pro Mags 7/16, Comp R lifters, EX 612 valve springs, 3200VIG stall, 3.73 gears, fully built a4, 30#SVOs, Racetronix FuelPump, Hooker Longtubes, true duals, and a K&N FIPK.
Obviously since I have a 94 I have a non-vented OPTI. Now my car has about 106,000 miles on it. I am also not sure if the OPTI has been changed recently.
SO I plan on swapping to a vented OPTI when I do my cam install. So my question is, can I run the LT4 ED timing setup on top of the vented OPTI and get by with that. I really don't want to run a electric H2O pump as I just bought a brand new lifetime warranty stock water pump.
I know that the LT4 ED timing chain has held 1100hp 4th gens, so I am not concerned about the strength or reliability of the unit. I just want to make sure that the timing setup will work with a vented opti setup and no other upgrades needed.
Thansk
Old Jul 13, 2004 | 09:21 AM
TQdrivenws6's Avatar
I am sure you have heard this before, but I will suggest a double roller SBC timing set (87+) along with a CSI, it will cost damn near the same price, and you can get some power out of it too. Personally I think the best feature about it is that the pump can run when the car is off.
Old Jul 13, 2004 | 12:05 PM
The LT4ED will work fine with your new cam and vented opti. Make sure you get the other conversion pieces, like a 1995 timing cover and the opti electrical and vacuum harnesses. Also check the dowel pin length on your new cam. ~.650" is what my stock 1995 dowel pin was.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 23, 2015 01:13 PM
Brent94Z
Mar 21, 2002 04:44 PM
