need picture of throttle cable bracket
Old Oct 13, 2007 | 01:34 AM
doug791's Avatar
I'm trying to put an LT1 throttle body on my L98 stealth ram motor and my cable is not the right length, the throttle blades are being held about 25% open.
Can someone please get me a picture of the bracket that the throttle cable runs through on the inside, because if it is the right shape to bolt up to my stealth ram i will just get that bracket and should hopefully locate the cable in the right place.
Old Oct 13, 2007 | 09:18 AM
This shows it from the front. It bolts to the manifold with (I think) three bolts.
http://www.injuneer.com/images/photo...e/DCP04253.jpg
This is the view from the side:
http://www.injuneer.com/images/photo.../DCP04257a.jpg
I realize the shock tower brace is in the way, but those are the clearest photos I could find.
Old Oct 13, 2007 | 09:26 AM
Shoebox also has a photo:
http://shbox.com/1/pcv_pipe.jpg
Old Oct 13, 2007 | 12:41 PM
doug791's Avatar
thanks for finding those pics that really helped
unfortunatly for me i was hoping that bracket would bolt up to the side of my stealth ram. i'm trying to put an LT1 throttle body on my stealth ram and the tpi throttle cable bracket makes the cable too short at the throttle body for the lt1.
heres a pic you can see that the cable wont let the throttle blade come back to the idle screw by about 1/4"
Old Oct 13, 2007 | 02:00 PM
bingo's Avatar
That is not an F body LT1 throttle body. It might be early LT1 TB for a vette. The F body LT1 has a half circle throttle linkage on it. Like in Injuneer's second pic.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 25, 2015 02:41 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
